TPS voltage Q's
Also, while I had the AutoXray connected I decided to look at the TPS voltage (the car idled a little too high IMO) What I found was .62v - I think this is ok.. is it?
The thing that really bothered me was the throttle blade shows to only open to 78% at WOT..... now that bothers me.
Would there be a reason it was set to this?
Another question is - Does the "Throttle Performance Switch" make any differance? According to what I have read about them, it makes the computer think the TPS is at 4.6v (WOT) when it's at 60%+ blade position.. delivering maximum fuel and timing for better performance.
RACE ON!!!
Concerning you question re: code 33. Similar to the TPS, the MAP has three wires; Gray is the 5V reference; Lt Green is the MAP signal; Blk/Pink is the ground. Signal voltage varies from 1-1.5 v at idle to 4.0-4.8 V at WOT. You can use the auto-xray to read MAP voltage (I guess, I can do this with my Snap-on Scan Tool, anyway.) The code sets when:
* Signal voltage too high for > 1 second and
* TPS less than 2%.
A low or unstable idle can also set a code 33. You must correct any rough or unstable idle before diagnosing a MAP problem.
Test:
* Auto-xray in scan mode
* Ignition off. Disconnect MAP electrical connector.
* Ignition on. Does scan tool read a voltage of 1 V or less?
* YES: Probe sensor ground with a test light to battery voltage -- test light should light. If YES, vacuum leak, or faulty MAP. If NO open ground circuit.
* NO: MAP signal circuit (lt Green) shorted to voltage or reference circuit (gray) shorted. Or faulty ECM (unfortunately that's always there
) .Jac
