383 is in and running !!!
I did take her out for a quick jaunt around the block and lets just say she is quite "snappy". I still have a bunch of tuning to do but now I can at least sit in the drivers seat with the laptop.
The EM headers were a easy install and fit real nice.
For those of you 84 owners out there here are the specs of the motor.
Block - 95 4 bolt roller
0 Decked
Quench Distance - 0.039"
Rotating Assy - Eagle stroker kit (Crank, Rods)
Speed Pro Pistons with -12.5 cc D Dished
Moly Rings
Internally balanced
6 3/4 Inch harmonic balancer from Summit
Scat flexplate for late model block
Heads are TrickFlow 195cc intake runners with 64cc chambers Compression ratio 10.4:1
Cam - Compcams CS XR269HR-12 (pn 08-502-8)
Duration @ 0.05 218/228 LSA 112
Lift with 1.5 Rockers - .495/.503
Lift with 1.6 Rockers - .528/.536 (I did this)
Summit Roller Lifters
Roller Rockers 1.6 ratio (from ProComp in Australia)
XRam with 2" TBs and 90 lb Injectors
Headers - 1 3/4" Tubes, Ceramic Coated inside and out from Exotic Muscle (www.exoticmuscle.com)
I just may need to go around the block a time or two more while my neighbors are at work.
RACE ON!!!
So your TB balance tubes are still functional?
RACE ON!!!
The balancing tubes are still functional but touchy. My yardstick manometer does the trick. I have a unisync and I will be making a can with the unisync on top to help with balancing.
Here is the prototype unisync balancer.
