what a dummy
Old Apr 25, 2005 | 06:27 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Default what a dummy
" So I have this friend " that removed his intake to replace the gaskets and when I did, I mean he did, he forgot to mark the distributor, so how screwed is he/me going to be to try and get it back on and in time without pulling the heads to figure out which piston is at top?
go ahead, point and laugh i deserve it
Old Apr 25, 2005 | 06:41 PM
bogus's Avatar
bogus
remove plug #1, turn over engine until you get a poof, meaning top dead center, and install distributor with rotor pointing at #1 plug wire.
Old Apr 25, 2005 | 06:47 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
mr dummie, er i mean flannel man
pull spark plug #1 and put a finger over the spark plug hole. have
some one bump the starter over until the compression blows your finger off the plug hole. look for the timing mark on the damper and bump or rotate the engine untill the mark comes to about the 10-12 btdc mark on your timing tab. line up the oil shaft and drop the distributor in, making sure it seats on the intake surface and point the rotor to #1 plug terminal on the cap, this should put you in the ballpark to start. clamp down the distributor and time as normal.
Old Apr 25, 2005 | 07:37 PM
ALLT4's Avatar
ALLT4
Make a home made whistler, it's a blast!
Old Apr 27, 2005 | 10:17 PM
flannel_man
thanks for the help i'll try that after the intake is ported, and let ya know how it goes
Old Apr 27, 2005 | 10:27 PM
USCG's Avatar
USCG
AllT4--that is slick!
Old Apr 27, 2005 | 11:02 PM
Pete K's Avatar
Pete K
Excellent idea! Like a fool, I spent money on the "correct" whistler. I would have done that in a minute if I were smart enough to think of it.
Old Apr 27, 2005 | 11:04 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
That also makes a good thread chaser in a pinch
To what a dummy
