Problem after installing 1.6 roller rockers. Need ideas
I put a set of Crane 1.6 full rollers, and their replacement springs. It starts and runs fine until you get on it, and then at about 3000 rpm's it feels like it is shutting down. It feels strong and smooth up until this point. If I ease it up it pulls more smoothly, but still begins to feel like the valves are floating. I can rev it sitting in neutral, and it pulls strong up to 5000 rpms +. With a load it won't.
Any ideas on where to look would be helpful. Thanks, Tom
If I had a dollar for every time some one posted that they had set their lifter preload correctly, only to find out later they hadn't, I could retire. Oh, I forgot, I'm already retired. LOL
Give us the details, this one doesn't sound too complicated.
Jake
It pulls up to about 3000 rpm's and falls on it's face. Starts and idles smooth as glass.
I have built several small block hyd lifter engines for my early vette with no trouble. The only difference was they weren't roller lifters or full roller rockers. I thought maybe there was something I didn't know about them( it's beginning to look like there's something I don't know!)
I'm am open to any of you guys suggestions. Tom
1. you need an LT4 knock sensor,mine would not run with out it.Knock counts above 30,000.GM dirrect $39.95
2. I would install a Worlboro 20000169 fuel pump.
or you could readjust the valves.
http://corvetteactioncenter.com/foru...ad.php?t=45701
The ECM runs a test on the knock sensor circuit each time the engine is started. It sends enough timing to cause the sensor to respond and when the sensor does, the ECM knows the circuit is okay.
If no response is received, the ECM causes the SES dash light to illuminate and it remains on until the engine is shut down and restarted.
You can installed a 1/4 watt resistor into one of the ESC module wires. this resistor simulates the signal the ECM is looking for and assumes everything is okay with the circuit.
The resistor does, however, effectively disable the knock sensor. So if ACTUAL knock occurs, the ECM cannot retard the ignition timing and engine damage could occur. It's one of those "last resort" mods.
Hope this helps.
Jake
A couple of years ago, I installed such a resistor to the ESC module on my 86 and it works. I've since removed it and installed a different ECM module, 16038331, which is less sensitive to false knock signals.
If I have to increase fuel pressure, what's the best way?
It'll be loaded with information you will now and in the future. It'll even have step by step trouble shooting procedures for many of the most common problems.
On my 86 the knock sensor is located screwed into the passenger side of the block, down low between about cylinders 6 and 8 (or is it 4 and 6) anyway, it's round, slightly larger than a silver dollar.
To adjust the fuel pressure, the best way is to buy an adjustable fuel pressure regulator and a fuel pressue gauge. They're listed in all of the catalogs, like JEGS, Summit, PAW, etc. There are a couple of other ways to adjust the fuel pressure, but an AFPR is the best way to go.
Jake
