3.54 differential installed - Awesome!
I made the break in suggested (Three trip of about 30 miles letting cooling completely the differential between the runs...) then I made 2 80 miles trip always letting cooling it completely. Then made some short trips applying more and more gas pedal....
In the first 30 miles trip i noticed a Whistle...A quite definite wistle (very quite whistle...You need to be with your ears very carful to notice it but i was present...)
After these 30 miles trip, no more whine... OK, the unit is not quiet like the old stock unit, I can say that i can hear from the rear a minimal, minimal, minimal noise.
After about 300 miles I pushed hard and i can feel the difference versus the old 2.73 gears...
I really like it even at part throttle where my car was very lazy...
NO more the old sensation of lugging ...
I tried also on the track (not a real dragstrip...a racetrack with the christmas tree and the finish line at 1/8 .)
When i was with the 2.73 and the 2.73 unit I made passes only with G Tech pro and with the calculator of the Datamaster software.
My best on the street was 2.23 on 60 ft and around 9 sec on the 1/8
I made my best pass with a fantatstic 1.836 at 60 ft. , 8.357 ET on 1/8 mile. and the best ET mph of 81 mph. (I need horses...)
Someone know how to translate this 8.357 on 1/8 to 1/4 times??
-Beppe-
I found a calculator for translate 1/8 to 1/4 ET...
and a 8.357 is near to 13.10 on 1/4 mile...
Is it possible that my lazy car is so fast??
...and I have to say that it's my really first time at the track..
For compareision I burned all the C5 at the track
, except for a C5 with some mod that run consatant 8.10 / 8.20 on the 1/8 mile.Soon my car will be a 383 with heads and cam.
-Beppe-
-Beppe-
You prolly picked up 3 tenths or so with the gears though. To complement them , you should add a higher stall converter and add a neck-snapping 60foot to that..
right now my car is in breakin procedure as i did insatalled cam,
heads and rebuilt bottom end.
sami.
What kinda cruising RPM are you turning?
