1992 ground points
Old Apr 26, 2005 | 09:13 AM
Oly's Avatar
Oly
Default 1992 ground points
I looked in my GM manuals and could not find a listing of all the ground locations on my Corvette. I have found the ones towards the rear of the car and have cleaned them but for whatever reason, I haven't found any in and around the engine compartment, from above or below. I might not be looking in the right section in the shop manuals, so if someone could point me in the right direction I would appreciate it or just a simple descrition where to look on the car.
Thanks.
Old Apr 26, 2005 | 10:52 AM
Tom Piper's Avatar
Tom Piper
There is a ground on the frame in front of the battery.
On the engine block, there are several wires on the ground above the oil filter.
There is a ground wire on the bell-housing.
There is a ground on the block below and between the throttle body and ignition coil --this is where the tach filter ground is.
Tom Piper
Old Apr 26, 2005 | 01:12 PM
Oly's Avatar
Oly
Thank you, this should help a lot. Are they the standard grounding strap like back on the antenna housing?
Old Apr 26, 2005 | 01:33 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
The one near the oil filter is I think. The tack filter one is just a regular wire with a loop on it.
Old Apr 26, 2005 | 02:29 PM
bogus's Avatar
bogus
There are also grounds inside the car... one on each side of the dash... there are grounds in the back. If memory serves, there are 27 separate ground points on a C4....
I am surprised that the Helm Manual does not show where the grounds are.
Old Apr 26, 2005 | 03:34 PM
Wile'sVette's Avatar
Wile'sVette
Is there a separate ground for the speedo ? Occasionally, I'll go over a sharp bump, and the speedo will go to "0"... go over another bump, and it will come back on, although, lately it hasn't been coming back on as quickly as before. When it's not working, everything else (including cruise) is working. I've even replace the gauge cluster. "feels" like a loose connection somewhere. I replaced the ground strap to the bell housing, but that didn't seem to make any difference. Needless to say, it's maddening !!
Old Aug 12, 2013 | 05:10 PM
czeben's Avatar
czeben
Did you ever figure out what the problem was with the speedometer?
Thanks- Chris
Old Sep 18, 2015 | 12:58 PM
Salvo's Avatar
Salvo
Hello,
I have a 92 C-4 and I lost my taillights last night! Headlights come on but no taillights. Brake lights work. My interior lights stay on all the time weather I'm driving or parked! Has anyone had this problem???
Old Sep 18, 2015 | 01:33 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by Salvo
Hello,
pull the buttons gently out on the door switch then shut the door to ajust.
I believe there is a ground for the tailights behind the back tag plate.
Old Sep 18, 2015 | 07:50 PM
Salvo's Avatar
Salvo
I thought of that, but when I open the door, the door light "Door ajar" comes on and when I shut it, the door light goes off. Interior lights stay on! I took the headlight switch off and the lights still stayed on? Can it still be the switch???
Btw, taillights was a fuse!!!! I feel stupid!!! I thought if the headlights are working then the taillight should also... I didn't realize there are two separate fuses...
Old Sep 18, 2015 | 07:55 PM
Salvo's Avatar
Salvo
BTW Thank You!!! Antfarmer2
Old Sep 18, 2015 | 07:58 PM
antfarmer2's Avatar
antfarmer2
sorry I figured you tryed the fuse ok now see if your dome light is turned on
Old Sep 18, 2015 | 08:07 PM
Salvo's Avatar
Salvo
LoL! No I checked that!
Old Sep 18, 2015 | 08:16 PM
antfarmer2's Avatar
antfarmer2
push the buttons but they are easy to ajust just pull on them
To 1992 ground points
