tps adjustment
Old Apr 29, 2005 | 05:49 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The bottom line is, if you set it wrong the idle will be high, and when you try to start the engine it may not Idle right .
If the latter you will be buying alot of starters and flywheels.
Set it at .54 and set the IAC first with the engine COLD....
Read the link.
