Since they come on with AC line pressure the relays are fine and so is the ECM connection as well as power connections.
I bet there's a chance that when you replaced H20 pump that you may have unplugged sensor wires. If your 1996 lt1 is like a 90 l98 in this area, and I think it is, your temp sensor is located just under the thermostat housing up front. Make sure it's wires are not damaged or unplugged.
