Dead Battery / Interior Light Problem (need help fast)
Old Apr 26, 2005 | 04:04 PM
SDS Photography's Avatar
SDS Photography
Default Dead Battery / Interior Light Problem (need help fast)
Ok this weekend I had my stereo installed . While they were in there i saw that the light under the dash had been unplugged so i asked him to plug it in and it turned on, good, i thought. So 2 nights ago i notice that the lights stayed on after i got out of the car. well after pushing every button in the door and having no luck i remembered that they might turn off after time. so i went inside and asked my girlfriend to look in the car when she came over that night. she did and the lights were off. The lights also stay on while I am driving
Fast-forward to today, go out to the car put in the key: nothing
no charge at all
so I got it jumped and took it to get the battery tested, they said it was good but low charge - well no ****
i have always had problems with the 'door ajar' light and guess the guy before me did too so he just unhooked the lights under the dash
but I like the lights and want them to work when they are supposed to
any ideas?
Old Apr 26, 2005 | 04:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It could be the switch on the door pillar is not being depressed far enough.
Try taping a piece of shim on the door front where it contacts the switch prong.
First find out which is the problem switch: open the door, start the engine and manually depress the switch. If that doesn't kill the lights, try the other door switch.
Old Apr 26, 2005 | 04:28 PM
SDS Photography
you are talking about the switch on the body of the car right?
b/c there are also 2 on the door that dont seem to do anything
Old Apr 26, 2005 | 08:41 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The switch is on the door. It's held on by two small screws and sometimes the center gets pushed in. A new switch will appear to resemble a mushroom, or a pancake on a pin. Most times the pin gets pusehed in.
Old Apr 26, 2005 | 08:53 PM
SDS Photography
since it is dark I am about to go out there and see if i can find anything, I just drove home and the lights were all functioning correctly
To Dead Battery / Interior Light Problem (need help fast)
