I was hoping one of you guys could answer this question about a 700R4 trans. When I built my trans I used all good parts except I didn't have a 30 spline so I used a 27 spline input shaft that I had, now I want to swap to a 30 spline input shaft and I am not sure if there is anything else I would need to change other than just getting a new input shaft. If anyone knows of anything else that needs to be changed please let me know.
Thanks,
John
you will also need the correct 30-splint torque converter to match the 30-spline input shaft. But I really know zilch about transmissions - that's just what I had to do when I had mine rebuilt.
Thanks for the info. Can you clarify what you mean by the pistons in the trans? I know I need a new torque converter, I want to get a bigger stall which is why I am upgrading to a 30 spline. I also need a new pump stator but I'm not sure what else I will need.
Thanks for any input.
The input shaft is press fit into the aluminum input drum. You will be swapping the shaft/drum assembly not the shaft only. The aluminum drum contains apply pistons for the clutch packs. If you tranny builder is robbing a drum assembly (as most do) from a parts trans you have no worries. All the parts inside will match. The press fit of the shaft to drum is a somewhat weak point in the 700 r4.They rarely fail in mild horsepower/ torque applications. For the high output stuff they make a reinforcing sleeve that adds rigidity to the spot where shaft and drum meet. Long story short: do not swap shaft only. Be sure to swap drum/shaft assembly.
If I were changing the input drum, I would go with a 1988 & up drum, as these will hold an additional clutch & steel in the 3-4 clutch pack. The 1987's used the same part number, but they will not accept the extra clutch.
