Some add on questions
Old Apr 27, 2005 | 09:58 PM
cplonner's Avatar
cplonner
Default Some add on questions
Right now i have an 86' vette with ram air induction, hi flow runners and intake manifold, and vortec heads. How badly would my stock throttle body be restricting me?
how much power is the stock fuel pump good for? can i get a more solid power gain from a higher flow fuel pump?
how much power can you get outa a pulley kit and a ajustable fuel pressure regulator? How about roller rocker arms? Lots of questions
thank you for any answers!
Old Apr 27, 2005 | 10:07 PM
Pete K's Avatar
Pete K
I will give my opinion, since you asked. The stock throttle body and fuel pump(assuming it is up to par) are not a restriction at this point. A pully kit is worth 1-2 tenths in the 1/4. A fuel regulator is nice. It can be used to tailor your package as you mod. Roller rockers give little power increase. The are more benificial as a durability item. They also lower oil temps by as much a 10 degrees on a hot day. Remember these are opinions.
Old Apr 28, 2005 | 01:23 PM
GeosFun's Avatar
GeosFun
I believe the stock throttle body will support over 350hp so it should not be any restriction at this point. The mods you are asking about will produce only negligible increases. There are no easy/cheap mods that produce major increases outside of nitrous. This is because our C4's are already a well engineered and coordinated system. So it takes a bit of planning and $$ to decide where you want to be, hp-wise, and the simplest way to get there.
You might focus on a cam change and headers as a good place to start. And as long as you are into the engine, porting the heads. Gears and converter are also good candidates. Eventually the TPI-style runners will become the choke point when the engine can rev past 5000 and still make power. That is why so many move up to Superram or Miniram. The key is a balanced program.
Old Apr 28, 2005 | 02:09 PM
CFI-EFI's Avatar
CFI-EFI
You can test your fuel pump. If it holds pressure to and through your red line or shift point, there is nothing to be gained with a different pump.
Ditto the fuel pressure regulator. IF the air fuel ratio is where you want it, all you can do is mess it up by changing the fuel pressure. An adjustable regulator IS good for small adjustments in the A/F ratio IF you have determined that it needs it. Remember that a fuel pressure change is "global", it affects the fuel supply under all conditions. If the A/F ratio needs tweaking at a specific point, you need to burn, or have burned, a chip to address the specific problem. Changing parts just because someone else is using something is NOT the reason to do it.
RACE ON!!!
Old Apr 28, 2005 | 06:25 PM
cplonner's Avatar
cplonner
if the throttle body is not a horse power restraint can it add some?
when porting heads are there usually "dramatic" gains in hp?
i have about 350 horses in my car right now, my goal is 400 without nitrous or boost. does any one have any advice on how to get this extra power? i already have a 474. int/exh lift comp cam, high flow runners and intake manifold, vortec heads, hooker headers and a custom prom.
thanks for any advice
Old Apr 28, 2005 | 06:35 PM
CFI-EFI's Avatar
CFI-EFI
Have you heard of the chain, and it's weakest link? The TB isn't the weak link, at this point. You have a LOOOONG way to go before a bigger TB will be of benefit. But if you have money burning a hole in your pocket, go for it and see how much it hurts your performance.
RACE ON!!!
Old Apr 28, 2005 | 07:34 PM
cplonner's Avatar
cplonner
hurts my performance?
im not looking to waste money im just trying to reach a goal of getting my car close to high twelves in the quarter mile.
Old Apr 29, 2005 | 09:45 AM
JCD's Avatar
JCD
if that's the case you may be able to get your times without more horsepower, you may want to look into a new rear gear, if you have an auto a new stall would benifit too!
A dyno tune, if you haven't already had one done, should also help.
To Some add on questions
