Digitsl dash help
Old Apr 28, 2005 | 11:55 PM
Ibuyvettes's Avatar
Ibuyvettes
Default Digitsl dash help
Anyone know the fix for an 84-89 instrument cluster that intermitedly blanks out? When you slap the dash it comes back on. I know it's like dirty contacts, or a bad ground. I read what needs to be done a long time ago, but have forgotten it since I never had to do it.
Old Apr 29, 2005 | 12:36 AM
MacVette86's Avatar
MacVette86
Try this link:
http://www.corvettemagazine.com/1999...ash/dashp1.asp
You may ahve to copy and paste it into your browser.
Old Apr 29, 2005 | 12:40 AM
MacVette86's Avatar
MacVette86
Here's another one:
http://www.corvettemagazine.com/2001...igidashpg1.asp
jfb's Avatar
jfb
Do you mean that the back lighting goes out but the LCD bars are still working? Also, I recommend that you discontinue bashing your cluster.
Old Apr 29, 2005 | 01:30 AM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Do NOT hit the dash!!!!!!
They take suprisingly little abuse before the LCD panes break. Replacement panes are pricey.
Old Apr 29, 2005 | 01:49 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Your plug for the cluster has come lose.
Remove the bezzel center of the car.
Behind it yoiu will find a plug and 3 or 4 of the connections in the printed circuet have come uncliped.
Just streighten the printed curcet and plug the connector back in.
Old Apr 29, 2005 | 02:17 AM
steve1ph2's Avatar
steve1ph2
"bashing your cluster"? hmm? its got a ring to it.
Old Apr 29, 2005 | 02:21 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Go here.
More than you ever wanted to know about repairing your digital dash.
Old Apr 29, 2005 | 02:27 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Home repairs are easier than you'd think. I did mine inside two hours. Used a magnifying glas to inspect all the solder joints. Found a bunch of joints on the interconnect junction had gone bad and it only took ten minutes of soldering to get it right. I started to hit every joint on the power board until the magnifying glass appeared... Just goto the sites that everyone has mentioned here, read 'em through, and get to work.
I used the The 84-89 Digital Cluster Repair Guide Project by Bryan A. Thompson. It has some good illustrations and easy to understand text.
Old Apr 29, 2005 | 02:55 AM
jan-erik's Avatar
jan-erik
Default Digital Cluster comprehensive repair.
Hi.
I have found a site that realy helps you out of problems. It gives solutions on many aspects with cluster problems. I have used this and many of my friends with success.
http://www.batee.com/corvette/dcrg/index.shtml
Good luck
Old Apr 29, 2005 | 09:53 AM
Ibuyvettes's Avatar
Ibuyvettes
I know, I only did it as a way to test if it was really burned out or just a loosed connection. P.S. I'm Rick James B*tch!
To Digitsl dash help
