Super Ram Q's
Looking at buying one, but it's been gasket matched to Felpro 1205 gaskets.
Any help would be appreciated!
It doesn't make sense to only do the intake mod. I say this because if you're going to remove the intake, you're only a few steps from removing the cam. Why stop? You'll desperately need much better flowing heads w/good velocity (heads are the HEART of making power on an N/A engine) + a higher duration/lift cam (recommend the LPE 219/219), and absolutely open up the exhaust with long tube headers + high flow main cat + and dump the stock mufllers with some other configuration at the rear, of your choice.
Get all the parts first, and have the whole shibang done at one time.....saves alot of time, labor $$ bigtime, and/or patience if you're doing it yourself. Then you'll be somehere in the 375-400chp range (or a little more) and alot happier because of it
I have long tube headers, Corsa LT1 exhaust system, 52mm TB, Accell 300+ Ignition & coil, AFPR, Underdrive pullies, all smog stuff has been removed, no cats - I was told when i bough the car that it had an aftermarket cam - I have no idea of what the specs are..
I figured the SR would be a great addition to what I have now, but the port work on the intake bothers me a little...
So I guess my question is - would the "step" really hurt performance?
Should I look for an un-ported intake and later have the heads and intake ported at the same time?
also add the SR intake into this mix
Wasting time and money in my opinon. Only way to get noticeable hp/tq gains on the l98 is cam/heads/headers or stroke it to 383/396 package.
Looks like both of ou have a SR intake...
Are you saying the SR is a waste of money? Or are you saying to build a 383/396 with a stock intake??? Or build a 383/396 with a SR??
The way I see it... If I have a SR intake on the car now with the mods I have - it will make it run better - Right? And if I build a stroker motor, I'll have a good induction system.. So buying a SR now is NOT a waste of money?
All I really want to know is - Is the SR a good intake?
I passed on the ported SR and now looking at a "new" SR
Am I headed in the right direction?
But anyway, by SOP I feel a great difference from the SR compared to the stock TPI. I dont race as there is not a local track, and I dont have a local dyno either. But I do understand what they are saying about having to pull your heads to do it, might as well keep going. If you are not sure about your cam specs, i would consider the 219. I have the hotcam and want more.My .02
Doug
ps. If you ARE for sure going larger cubes, go for it! It will only help now, and will definitely benefit greatly later!
The SR is a good intake. I have one my 85 383ci engine. The stock intake on a 383/396 is not the way to go. You need more air which the stock intake system can't provide, ported or unported.
When I put the SR on I had stock exhaust manifolds and stock rockers. I didn't feel a big difference (except the 4500rpm "wall" had gone and it revved harder). After some time the car dynoed about 20hp better than its previous run (stock chip).
Putting the 1.6 rockers made the biggest difference for me (after the headers were installed).
Not knowing what your cam specs are makes it a bit of an unknown but assuming your cam was close to stock I would recommend waiting until you are ready to do the cam as well. For all the work involved in the 1st install (it gets easier after the first time) I would wait until I was ready to do heads and cam at the same time if I had to do it over again myself (especially given how much you are investing in the SR in the first place). Right now my car goes better than it ever has but I know my cam is holding me back in a big way.
I have a 219 cam on order now and am looking forward to installing it and doing the chip and some headwork at the same time.
Short version - you will likely notice some gains just by putting the SR on but they are nothing compared to what you will get if it is matched with the correct cam along with headwork and programming.
Hope this helps.
