88 Crazy High Idle Problem! PLEASE Help!
Old Apr 30, 2005 | 03:35 PM
black88z51's Avatar
black88z51
Default 88 Crazy High Idle Problem! PLEASE Help!
New iac;new egr valve;vacuum looks good, no visual leaks; removed 52mm throttle body and cleaned, opens/closes OK; correct TPS sensor reading; throttle cables look good, -no binding. Starts and idles OK at 800 rpm, but once I depress the gas all hell breaks loose. Idle jumps up to 1300 and stays there, when driving it's like having cruise control on, the damn thing sticks at 1300-1600 rpm enough to keep the car moving well. The only way to bring the rpm's back to normal is with a quick depress of the gas pedal. It's like the throttle's getting stuck, but strangely the throttle body is closed and resting against the adjustment screw then it happens. Had code 32, fixed it with new egr valve and now no more error codes reporting. I'm thinking it might be the ECM, could it be bad? but before I get one I though I'd ask if anyone had a clue as to what's going on with my car.
Old Apr 30, 2005 | 11:38 PM
_twisted_'s Avatar
_twisted_
Worn bushings on the TB?
Old Apr 30, 2005 | 11:45 PM
black88z51's Avatar
black88z51
Tomorrow I will try swapping the 52mm with the original 48mm and see what happens.
Old May 1, 2005 | 04:26 PM
black88z51's Avatar
black88z51
TB was no good. when I swapped it with the original the problem was gone. I could feel a little bit of play within the shaft of the no good TB, but I didn't think it would of made that much of a problem. Does anyone know what the allowable tolerance is between the shaft and the bushings? What about the bore and the plate?
Old May 1, 2005 | 04:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since the throttle is resting against the stop screw, the only way air could be getting in at the TB is if the bushings are worn and leaking in air.
A scan tool would tell you if the ECM is calling for high idle or trying to lower the idle.
Old May 1, 2005 | 10:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
Its acting up on purpose hoping you'll freshen her up and do the head/cam swap!
Old May 1, 2005 | 10:41 PM
sniperdiver37's Avatar
sniperdiver37
What brand 52mm TB was on it? (The bad one) and how old was it?
Old May 1, 2005 | 11:11 PM
black88z51's Avatar
black88z51
it was a bored out original 48mm, out of a 89-91 that had the cable connector modified. who makes the best 52's? is BBK a good one?
Old May 2, 2005 | 02:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
Id' recommend not using BBK. Ever Many QC issues
Old May 2, 2005 | 04:46 AM
ClarenceT's Avatar
ClarenceT
Just curious, but why do you need a 52mm TB?
To 88 Crazy High Idle Problem! PLEASE Help!
