Ceramic Coated Y - Pipe
Old May 1, 2005 | 11:38 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Ceramic Coated Y - Pipe
Should the Y-pipe be ceramic coated?
Why or why not.
Old May 2, 2005 | 12:24 AM
vettefun's Avatar
vettefun
I've "HEARD" airflow is smoother traveling through coating, but someone please chime in and verify.
Also be careful, I've heard to not coat the inlets/outlets a couple inches off because the extra coating has caused fitment issues sometimes making it too tight to get on and then you wind up grinding off coating at the tips to make fit.
Just passing on stuff I remember reading on the forum.
Old May 2, 2005 | 02:00 AM
tjwong's Avatar
tjwong
Why or why not.
Coat it for corrosion protection, beautifying but for any other reason. It is not really necessary. I coated my X pipe but it was because it's made of mild steel so I went after corrosion resistance.
Old May 2, 2005 | 05:23 AM
85vet's Avatar
85vet
Cruise-In V Veteran
I coated mine - It cut my undercar heat in tranny tunnel down substantially. This was the main reason I wanted to do it .
To Ceramic Coated Y - Pipe
