Need help guys...please
Old May 2, 2005 | 02:08 AM
Reddy94's Avatar
Reddy94
Default Need help guys...please
Under the right side fuel rail cover there is a connector in between the inside injectors...4 wires grey female/black male plug. One of the wires is completely broken. I traced one end to the opti...the other end I believe goes to the left side injector bank... Problem is the wire broke off inside the connector. How can I repair? I am stationed in Italy and would have to order a new one on line as there are zero parts houses here.
Thanks for any suggestions!!
Old May 2, 2005 | 07:31 AM
RichS's Avatar
RichS
Some tool supply places sell little tools to remove conectors from factory harnesses. You insert it in the end of the connector and it pops out the metal connector. You can then try to resolder the wire back on, then push it back in.
