Free Mods?
Old May 2, 2005 | 01:46 PM
SDS Photography's Avatar
SDS Photography
Default Free Mods?
I keep reading about free mods for a L98, where can I find them?
Old May 2, 2005 | 01:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check out my site for a few low cost/free mods.
What year L98 do you have?
Old May 2, 2005 | 02:05 PM
SDS Photography
89'
Old May 2, 2005 | 03:38 PM
65Z01's Avatar
65Z01
Ok here are a few free or low cost effective mods:
-10chp-remove the "frisbee" from the front of your water pump pulley, see my site for details, free
-8chp-install cut-back stock style AC Delco spark plugs, details & pic on my site, $12-$15
-10chp-install a 160deg T-stat and aux fan switch; wire the aux fan switch to control the main fan relay, $80
-10chp-install a K&N with cut air filter lid, $40
Of course you will see some large gains from the more expensive exhaust mods:
-20chp-2 1/2" front Y, hi-flow cat, hi-flow cat-back, $800-$1200
-18chp-ceramic coated FL headers, $500-$800. This would be a nice alternate to doing the 2 1/2" front Y
The free mods will take your power level up from 240chp to around 280chp; then the exhaust mods can raise it to around 320chp.
At this point you should also install an AFPR so you can bump fuel pressure a little, as you will need more fuel flow at WOT.
Beyond that you can do heads, cam and intake mods to push very close to 400chp, maybe closer to 380-390chp and still retain or boost the low end torque as well as extend the upper RPM range.
Old May 2, 2005 | 07:40 PM
ryjova's Avatar
ryjova
1st Gear
I have a question about removing the frisbee, if you do, can you still run the ac without the belt coming off?
Old May 2, 2005 | 08:07 PM
65Z01's Avatar
65Z01
Absolutely!
Gordon Killebrew told me that it was put on in '88 with the new style compressor to keep the belt from squealing sometimes when the A/C compressor cut on/off.
Old May 2, 2005 | 08:52 PM
SDS Photography
so is that just for the 88 then?
your site says they changed the style in 89
Old May 2, 2005 | 09:28 PM
65Z01's Avatar
65Z01
The style of the "frisbee" changed in '89 but it stayed with the L98 through '91; it was not used on the LT1s, from '92 forward.
Old May 2, 2005 | 09:55 PM
jzvette's Avatar
jzvette
65Z01,
I have an 89, so your telling me that if I take off the frisbee I'll gain HPs and there will be no adverse effect to my engine, noise or otherwise??JZ
Old May 2, 2005 | 10:05 PM
mash2k's Avatar
mash2k
I will remove my frisbee soon so I will let you know how it turns out. I am interested in this post because I am looking to do some of the more easy low buck stuff before I delve into the $$$$$ mods.
So far other than a good tune up and a K&N, the only mods I have made are a high flow cat and magnaflow cat-back. Not sure I can feel any difference. Hopefully the sum of many small mods will net a difference.
I think my next mod will be hooker 1 3/4 headers.
Old May 2, 2005 | 10:12 PM
jzvette's Avatar
jzvette
Does anyone know if there are any down sides to removing the frisbee???
Old May 2, 2005 | 11:43 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I think the 89 thru 91 L98 only had a 3lb. frisbee whereas the earlier 85-88 had a 10 lb. lunker. So don't expect a 10chp increase on the later C4 L98's.
I got rid of my 3 lb.'er on my 90 with no adverse reactions but I didn't feel a big sotp difference either. Every little bit adds up though. So do it.
Old May 3, 2005 | 12:12 AM
jzvette's Avatar
jzvette
Skateparkdave,
Thanks for the tip, what was the purpose of this weight to begin with???
Old May 3, 2005 | 12:25 AM
skateparkdave
Skateparkdave,
As 65ZO1 stated, Gordon Killebrew says it was designed to dampen the cycling of the AC compressor and reduce the belt squeal. Later they decided it was obsolete.
Old May 3, 2005 | 12:31 AM
jzvette's Avatar
jzvette
Thanks Dave, so just unbolt it and more horsees. Not the 10 but every little bit helps. JZ
Old May 3, 2005 | 12:44 AM
skateparkdave
No prob JZ. One more thing, if you have the 3 lb one, I had to put the pulley bolts back with a lockwasher each to replace the thickness of the boltpoints of the frisbee. Without the washers the bolts tightened up before the pulley was snug. So use either shorter bolts or lock washers.
Old May 3, 2005 | 12:45 AM
stevec4's Avatar
stevec4
Rather than cutting back the spark plugs, take a look at the Bosch Platinum+4 plugs - $5 apiece.
They have 4 side electrodes that opens up the flame path and being platinum tipped they should last longer too.
To Free Mods?
Old May 3, 2005 | 12:52 AM
jzvette's Avatar
jzvette
SPDAVE,
Have noticed any belt squeal at all without the frisbee?? JZ
Old May 3, 2005 | 01:12 AM
skateparkdave
Do a search, alot of members frown on the Bosch platinum 4 plugs and say.. I had them and had a low idle miss shortly after installing. I then switched to cut back AC delco rapid fire #5's and had great success. I recently switched to a colder NGK plug to run with my nitrous which brings up another thing..never run any platinum plugs with nitrous. Never.
SPDAVE,
Nope, not a peep.
Old May 3, 2005 | 01:15 AM
jzvette's Avatar
jzvette
SPDAVE,
How do you get the stars after your name???
