Knurling valve stem guides?
Old May 2, 2005 | 10:17 PM
JTHVETTE's Avatar
JTHVETTE
Default Knurling valve stem guides?
What is the general concensus on "knurling" valve stem guides? Is this a short term repair? Is this as good as "new" valve guides? Is it a waste of time and money? I have the option to have a set of LT1 heads done this way or new valve guides.
Thanks,
JTHVETTE
Old May 2, 2005 | 10:19 PM
Pete K's Avatar
Pete K
Do not waste money on this. It is Mickey Mouse.
Old May 2, 2005 | 10:21 PM
JIMBO7's Avatar
JIMBO7
long time repair is new guides. do it the right way 1 time!
Old May 2, 2005 | 10:25 PM
Pete K's Avatar
Pete K
I like to press bronze liners into the cast iron guides. If you press out the stock iron guides, the press fit is sometimes lost. This makes full bronze guides nescessary. These are very expensive. Bronzem liners are cheap and seem to work well.
Old May 2, 2005 | 10:37 PM
Gar's Avatar
Gar
knurling is a waste of time. It won't last and will have to be redone the right way.
Old May 3, 2005 | 12:43 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I think you have your concensus..... I didn't even know this was done anymore. Definitely not a fix for a modern high performance engine.
Old May 3, 2005 | 02:00 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
After the new guides have been pressed in have them honed to size, not drilled.
To Knurling valve stem guides?
