Finally got her Dynoed
anyway that is my story it has been a year in the works. so thanks for listening.
unless your unsatisfied with that level of power though, maybe just pulley it down for the time being and play on the safe side.. after all.. 722 is quite a bit of power to play with! and you know the hard work is done, so down the road when your used to it, you can always pulley it back up and have some fun!
Chris
Chris
awesome numbers though!
Chris
I want the guy that tuned your car!!!!
Did he only tune for WOT? Are you running 6 or 8 rib?
So, a 95 LT1 block could go around 1000 hp????
as for the LT1 block handling it.. it goes without saying that the opiling system will need to be adequate to handle the power, the machine work would need to be on point, and the balance of the motor and components would need to be topshelf. as long as the tune is proper and the engine is operating as designed without incidents of damaging knock, then yes the block can handle the power. as stated above, precautionary measures such as girdling the main caps and at least a 1/4 fill of the botom section of the block will help maintain the blocks form under load, and as long as this is accomplished, and the oil pressure is there.. yes should handle it fine!
I would not try and run 500 miles at 1000HP, as that in itelf is very tough on all aspects of engines.
Chris
As far power handling, I agree those are non nitrous figures.
Nitrous= high cylinder pressure
Forced induction= more Average cylinder pressure.
Having a denser charge, the forced induction burn lasts longer and has far more cylinder pressure present when the crank is at 90deg.
At 3.5" blower pulley and 5800 RPM, I believe you are only turning the impellor to just shy of 53000 RPM. That should not cause any issues. I am very surprised by the 20 psi numbers that you quote, as I turn mine to within 500 RPM of max impellor speed and see less than 15 psi. What kind of I/C are you running?
As for the modifications to the brackets, I think you will find that most on this forum are aware of the modifications that are required on the P-600B, P1, P1SC, D1, D1SC, D1R, D1X, and F1R that are required to make the belt "wrap" around the pulley better for better grip. This is a somewhat simple mod, but you might have to involve your local machine shop if you are not proficient with a tig or the drill press (dependent upon model).
I would like to see the pics of this motor. Always nice to see other's pics.
QuikETs,
The D1X is not the same as the other D series blowers. The D1 and the D1SC have the same size volute (~1400 CFM), but the D1X has a different tranny case and could flow more (~1750 CFM) than the standard D-series blowers. This was an older blower that was replaced in ATI's line-up by the D1R (~2000 CFM). This was done at the same time when the D2X was phase out and the D2R (~2800 CFM) was brought in to service.
As to the comment on the D1R not seeming larger than the others, the D1R has a 9.75" diameter volute compared to the 9" volute on the D1 (and also wider), and a larger transmission case. Side by side, the R series are larger than the standard D series, and this shows as you try to mount it onto the C4 chassis. ATI says it can not be done.
Aaron
