Water pump replacement question
Old May 3, 2005 | 07:25 PM
Reggied's Avatar
Reggied
Default Water pump replacement question
I am trashing my old water pump. I noticed a sensor screwed into the front section of the old water pump. I know I need to remove this sensor and screw it into my new water pump. My question is do I need to apply anything to the threads of the sensor upon screwing it onto the new water pump. ( tefton tape, lock-tight, etc.)
Old May 3, 2005 | 07:48 PM
Strick's Avatar
Strick
Make sure you use a conductor type thread compound as most sensors need to make a ground to work.
