drag race shifting
Old May 3, 2005 | 08:50 PM
canon1414's Avatar
canon1414
Default drag race shifting
how do you guys shift when your racing do you drop the cluch when starting and does anyone double cluch or have any other ways.
thanks mike
Old May 3, 2005 | 08:52 PM
STL94LT1's Avatar
STL94LT1
Why would you ever double clutch a Corvette?
Old May 3, 2005 | 09:04 PM
canon1414's Avatar
canon1414
i dont know i was just talking to a guy with a 2000 mustang bullit and he said he double clutches when he races
Old May 3, 2005 | 09:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well that's a Stang owner...
You will need to find out what launch procedure gives you the edge between bog and wheel spin.
Down the track just power shift it for the best times, or shift normally to be safe.
Old May 3, 2005 | 09:43 PM
scorp508's Avatar
scorp508
He must have a transmission built before WWII then.
Me.... right foot to the floor and jab the clutch with the left while pulling the shifter.
Old May 3, 2005 | 10:43 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Doubleclutching is for trucks.
I love how people try to find ways to shift better, the way SCorp describes is the only way.
Every car and driver is different, you have to find your spot.
Here is a video of me and how I do it.
http://temp.corvetteforum.net/c4/mrm...ovspanuzzo.wmv
and sometimes I do spin off the line
http://temp.corvetteforum.net/c4/mrmojo2//e-0006.wmv
Old May 3, 2005 | 11:20 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Nice!!! videos!!! I have a 96 LT4 and once I launch... my right foot never leaves the floor board. If you have crafty footwork and can stab the pedal and jerk the stick kwikly... you will only rev 200-300 rpms during shifts.
Old May 3, 2005 | 11:28 PM
Mr Mojo's Avatar
Mr Mojo
http://temp.corvetteforum.net/c4/mrmojo2//shiftvid1.wmv
Old May 3, 2005 | 11:34 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
pretty nifty shifty
(it's the chevelle from pump gas drags, for those that have seen it already)
His shifts sound like an F1 car.
Nice videos Mojo!
Old May 3, 2005 | 11:40 PM
ddsovy's Avatar
ddsovy
Great Video, but man I'd hate to redline my stock motor like that...
But F*** oh dear what a ride!
Old May 4, 2005 | 12:08 AM
froggy47's Avatar
froggy47
Originally Posted by RainDelay
pretty nifty shifty
Nice videos Mojo!
Is that a backfire when the Chevelle shifts?
It's a stick, right?
Old May 4, 2005 | 12:11 AM
OdinsRage's Avatar
OdinsRage
yea if thats a stock LT1... wow, high shifting!
Old May 4, 2005 | 01:13 AM
crkemppainen's Avatar
crkemppainen
pretty nifty shifty
Nice videos Mojo!
WOW that was hard core
Old May 4, 2005 | 01:17 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
How much do you shave off the ET that way?
I haven't tried it yet, although I've done a few where I got back on the gas way too early with the clutch still in, so that's just as hard on the tranny and drivetrain, if not worse.
Now is as good a time as ever to learn, since I plan on rebuilding it this winter.
Old May 4, 2005 | 07:23 AM
Mr Mojo's Avatar
Mr Mojo
The Chevelle has a 5 speed, one of those where you don't need a clutch to shift. The backfire is from the nitrous.
I rode behind that car in the ride and drive portion of the Pump Gas Drags. That car was so loud it was shaking my buddy's vette and we were 30 feet behind him!
Yes my LT1 is stock and that was nowhere near redline. The factory tachs are off by a few hundred rpm, I really have no idea what RPM I was at, but I do know that I didn't hit the rev limiter at all which is set at 5800.
Old May 4, 2005 | 07:44 AM
mseven's Avatar
mseven
Not powershifting... lifting on the loud pedal? why? its the only way! Although a good safety net here, is to make sure your rev. limiter is functioning and set correctly (drive shaft loop doest hurt either)
As to the launch, its always about being hooked (bolted)
Ever watch what guys in SS/AS to PRO/S do ... now that is really scarry, leavin the line at valve float w/a 500in. motor and hooked
I Watched Mojosfirst video great job! I agree W/Mojo, it doest sound to me like you were wound up (motor) that tight
Old May 4, 2005 | 11:06 AM
JCD's Avatar
JCD
P.S. Do not powershift while in a turn.
To drag race shifting
Old May 4, 2005 | 12:59 PM
VAHROOM's Avatar
VAHROOM
Default Pps
Point of order. Do not turn whilst on a dragstrip. Except to head for the pits at the end.
Old May 4, 2005 | 05:33 PM
GeosFun's Avatar
GeosFun
I just put mine in D, lean back and grin. Seriously, those are both COOL videos. They took me back to the days of my '66 Impala SS.
Old May 4, 2005 | 05:47 PM
psychodiagnostik's Avatar
psychodiagnostik
Double clutching (a.k.a. rev-matched shifting) is for downshifting, I do it all the time, it is SO awesome when you learn to do it. Most people mention it within the context of heel-toe downshifting, which is awesome X1000, but it's easier to learn to do when you are simply downshifting, like when passing another car on the interstate.
First, press the clutch pedal, and put the shifter in neutral. Then, (this is what most folks leave out) let off the clutch pedal. Rev the motor to whatever RPMs THE ENGINE WILL BE when you engage your chosen gear. As soon as she hits the correct RPM, push in the clutch pedal, and select your gear, release the clutch, and take off without upsetting the balance of the car. It's beautiful and the most satisfying part of the driving experience, in my book. It's real easier with a lightened flywheel, ultralight valvetrain, and underdrive pulleys, all of which allow the revs to drop and climb faster while in neutral.
The whole "double-clutching when drag racing" buzz is totally contrived and comes from a line in the Fast and Furious flick.
