dia. for harmonic balancer/damper
Old May 4, 2005 | 08:40 AM
bumpnzx3's Avatar
bumpnzx3
From: Edwardsville, Illinois 88 stroked s10, 92 stock 6spd
Default dia. for harmonic balancer/damper
i was searching for a harmonic balancer for my 383 l98 (internally balanced)- and i noticed that there were a few different diameters to choose from- which do i get?
Old May 4, 2005 | 02:49 PM
CFI-EFI's Avatar
CFI-EFI
For an internally balanced engine, the stock damper will be the easist. The timing marks will be in the right place and be closest to the timing tab.
RACE ON!!!
Old May 4, 2005 | 03:01 PM
8388's Avatar
8388
St. Jude Donor '14
I've been very impressed with Fluidampr.
Old May 4, 2005 | 03:15 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
have had no problems with mine, 11 years
Old May 4, 2005 | 04:00 PM
bumpnzx3's Avatar
bumpnzx3
i dont have the stock one- i got this bare block from a friend of mine. the fluidamper looks good- but what size- summit had a couple different diameters listed
Old May 4, 2005 | 04:22 PM
8388's Avatar
8388
St. Jude Donor '14
I'm running the 6 1/4" on my internally balanced 383.
Old May 4, 2005 | 04:25 PM
Dougs 90's Avatar
Dougs 90
6 1/4", I don't think anything larger will fit.
Doug
Old May 4, 2005 | 06:24 PM
Strike3's Avatar
Strike3
My L98 stock damper is 6 3/4". I measured it to compair to Fluidamper, which is 6 7/8".
I'm getting the Fluidamper.
Old May 5, 2005 | 12:16 AM
eguyett1985's Avatar
eguyett1985
I have a 7 1/4" Fluidamper on my internally balanced 408 and it fits with no problems.
Old May 5, 2005 | 05:51 AM
conv90's Avatar
conv90
The stock neutral L98 is 6-3/4".
You have room for a 7" damper at the timing tab on the timing chain cover , and about 7 1/2 to 7-3/4" to clear the crossmember .
A question.
Which 383 internally balanced kit have you purchased?
-Beppe-
Old May 5, 2005 | 08:25 AM
88421VETTE's Avatar
88421VETTE
you don't want to know the kinda headaches you can get from running an 8" dampner well unless you already know that it won't clear the crossmember go with a 6 3/4
Old May 5, 2005 | 01:09 PM
RWDsmoke's Avatar
RWDsmoke
I tried to use an 8" on my '86 and it did touch the crossmember. I bought a 6 3/4 from Summit. If you are on a tight budget like me they have one that is low priced, supposed to be better than oem and has timing degree marks built in.
Old May 5, 2005 | 05:41 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
bumpnzx3
Summit sell a 6.875" 'Street damper' (Fluidamper) which runs for $199. I was thinking of using this next. It isn't SFI approved, but seeing as I don't need SFI approval and therefore don't need to pay for it, it seems a reasonable buy and is the right size or better still, maybe a 1/8" larger than the stock one.
Dave
Old May 5, 2005 | 08:50 PM
88421VETTE's Avatar
88421VETTE
I picked one up off Ebay brand new for $54.99 shipped
To dia. for harmonic balancer/damper
