weak brakes afte brake work
Old May 4, 2005 | 02:26 PM
jay007's Avatar
jay007
Default weak brakes afte brake work
I chaged the rear brake pads on my 92 and ever since the brakes are worst, the pedal feels mushy and doesnt brake as good as it used too. any ideas why. I used the best ceramic pads available. I touched nothing else, just swap the pads and put everything back. I only replaced the rear. do I have to replace the fronts too, I wouldnt think that would matter. thanks in advance.
Old May 4, 2005 | 02:36 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
try bleeding the lines... I'd bank that you have some air trapped in there somewhere. Or you have a bad line
Old May 4, 2005 | 02:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Usually mushy feel is due to air in the lines.
Perhaps whey you depressed the pistons into the calipers some air got sucked in??
In any case you could try bleeding the lines. If it's never been done it would be a good idea to flush out the old fluid anyway.
Old May 4, 2005 | 02:39 PM
jay007's Avatar
jay007
but nothing was touched. brakes worked fine before putting in new pads. no lines were tampered with or anything.
Old May 4, 2005 | 02:43 PM
8388's Avatar
8388
St. Jude Donor '14
#1 the rears do very little to start with. #2 if the pedal feels mushy you have air in the system. In order to install new pads, you had to push the pistons back into the calipers. Make sure the seals or not leaking.
Old May 4, 2005 | 03:04 PM
Bilyk's Avatar
Bilyk
I disagree. I recently adjusted the rear drums on my beater and the difference was like night and day. Even if the car didn't stop any better, the pedal felt much firmer
Old May 4, 2005 | 03:07 PM
8388's Avatar
8388
St. Jude Donor '14
Old May 4, 2005 | 04:20 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Maybe pockets of air at the calipers? I'd try bleeding first and maybe a flush. (as suggested)
To weak brakes afte brake work
