problems after long tube install L98
Old May 4, 2005 | 07:33 PM
1989redvette's Avatar
1989redvette
Default problems after long tube install L98
installed a set of lingenfelter headers over teh winter (longtubes) .. now that the snow is off in pa FINALLY!! i have run a tank of gas through my 89 .. well the gas milage has dropepd from 21 to 14 !! the car also runs rich and seems to "hunt" for an idle i looked for the obvious vac leaks ect.. i am wondering if i may need a heated o2 or am i looking in the wrong direction.. i have not had the chance to get it on a scanner .. but just have a gut feel its the o2 any one else run into this after a long tube install ?
Old May 4, 2005 | 07:38 PM
Pete K's Avatar
Pete K
A heated o2 is always a good idea with long tubes. Check out the teck tip about it. It gives part numbers and prices.
Old May 4, 2005 | 07:49 PM
vader86's Avatar
vader86
Where is the O2 placed in the LPE headers?
Old May 4, 2005 | 07:53 PM
1989redvette
down by the collector on the left bank thats why i am thinking i may be too far away...
Old May 4, 2005 | 08:05 PM
JCAIRE2's Avatar
JCAIRE2
If the O2 is down in the collector like on my lingenfelter's, you'll need the heated O2. My car wouldn't even go closed loop at a steady cruise, let alone at idle.
Old May 4, 2005 | 08:09 PM
vader86's Avatar
vader86
Yeah if its in the collector its too far down, you will need the heated sensor.
Old May 4, 2005 | 08:13 PM
1989redvette
ok guys where do i get one of these and how do ya hook them up .. someone above said a tech tip has all the info how do i access that info?? i have used teh search before when it worked is the tech tip area different??
Old May 4, 2005 | 09:11 PM
vader86's Avatar
vader86
Tech Tips are listed under the "other" link at the top of the page
Old May 4, 2005 | 09:14 PM
1989redvette
thanks everyone for all the help.. looks like a trip to autozone first thing in the morning!
Old May 4, 2005 | 09:33 PM
game on's Avatar
game on
I would call Lingenfelter for advice. They should support you with this problem.
Old May 5, 2005 | 01:22 AM
JCAIRE2's Avatar
JCAIRE2
lingenfelter stopped making these headers a few years ago.
Old May 5, 2005 | 07:44 AM
scorp508's Avatar
scorp508
I bet they'll still help. They are VERY good with this kind of thing.
Old May 5, 2005 | 08:01 AM
1989redvette
i am sure they would help ... but i had a gut feeling when installing them that the 02 was too far away.. and to be honest i have never replaced it.. so i am gonna install a heated o2 today and go from there... it can't hurt and should be done periodiclly any how.. and by calling them they are gonna suggest a scan of the car to see whats going on and to make sure things are with in the set perameters ..
Old May 5, 2005 | 09:07 AM
theguardian's Avatar
theguardian
Default Lingenfleter won't help you... period
Has anyone w/an L98 take a look at their site lately? They barely, grudgingly support the LT1 C4 Vette. In any case, I also purchased a set of longtubes from Lingenfelter 3 years ago. They were pushing the Stainless Steel versions at that time. I then had the headers JetHot Sterling coated. I am using the original, standard O2 sensors w/no problems. Idle quality is great. There is, however, one problem which I may have created for myself. I also had the Y-pipe, the cat and the after-cat Y-pipe coated. The only thing I didn't have coated were the polished stainless mufflers. My cat-back system is a B&B Tri-Flow (VERY loud!). The problem? The ceramic coating keeps the exhaust gases SO HOT, that my rear bumper almost caught fire! The paint browned up a little (Arctic White) and the bumper was smoking!!! So I ended up having to reposition the outlets 1"+ from the bumper surface. Other than that, no problems. And it passes emissions w/o the air pump in Pennsylvania.
To problems after long tube install L98
