Removing Shifter Knob
Old May 5, 2005 | 08:52 PM
c-me-fli's Avatar
c-me-fli
Cruising
Default Removing Shifter ****
Need a little help! What is the best way to remove a automatic transmission shifter **** in an 89 Coupe? I am doing some recon work in the center console area.
Thanks and Happy Vetting to All
Old May 5, 2005 | 08:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First use a small flat blade to pry off the button.
Then you need a deep nose C-clip tool to release the C-clip around the shifter shaft.
Once the C-clip is out the **** should pull straight up; you may need to "prompt" it a little if it's never been off.
Old May 5, 2005 | 10:34 PM
rufneck's Avatar
rufneck
Default Deep snap ring pliers
Quote:"Then you need a deep nose C-clip tool to release the C-clip around the shifter shaft"
Make sure it's a deep snap ring tool or it won't reach. I bought a set of pliers that weren't "deep" and ended up taking them back . FYI I just used 2 flat screwdrivers and used the blade to spread the snap ring apart to get it off/on. Once it's off just pull the **** off.
Old May 5, 2005 | 11:28 PM
jzvette's Avatar
jzvette
Just changed my **** last week, I now moved on th the weatherstripping
To Removing Shifter Knob
