Low oil temp.
Old May 5, 2005 | 09:41 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Low oil temp.
As I drive around I run thru the digital gauges and when I get to the oil temp it reads "LOW" no matter how long it has been running. After about 40 minutes or so it will throw a code for "low oil temp". Now I'm figuring that either I poped the wires off a senser or it went bad. There is an oil temp sensor on the top of the LT1 motor in the back is this the sensor I need to be looking at or is there another one somewhere else? The analog gauge seems to be working fine so that leads me to believe that there is another one somewhere. Any one know where it's at?
Old May 6, 2005 | 05:49 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
what can no one answer this? I guess I will go back to digging thru the Helms.
Old May 6, 2005 | 06:57 PM
8388's Avatar
8388
St. Jude Donor '14
The oil temp sensor should be located just above the oil filter on the block.
Old May 6, 2005 | 10:31 PM
luvmy92's Avatar
luvmy92
I have the opposite problem.... my digital gauge works but the analog gauge does not.
Mike
Old May 7, 2005 | 10:06 AM
rick lambert's Avatar
rick lambert
Just curious-are you running a 160 thermostat?
Old May 7, 2005 | 11:53 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
Yes I am but that does not do anything to the oil. I did a lot of work to her this winter so I may have unpluged the sensor and forgot to plug it back in or I didn't know I unpluged it, most likely, that's the case. Thanks guys. I'll get her back in the air and check it out.
To Low oil temp.
