Sbc454
Old May 6, 2005 | 11:34 PM
BRICHC4's Avatar
BRICHC4
Default Sbc454
how feasable would it be to fit the world products 454 small block to a ZF6 tranny in a 95 coupe?
Old May 7, 2005 | 12:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
Sure it can be done. One or two piece rear main seal? Remeber those 454's are throwaway motors. Not enough room to overbore if need be. Ever consider a 415/427?
Old May 7, 2005 | 12:36 AM
NitrousSam's Avatar
NitrousSam
434 or 440 is another option. If you go 454 make sure you use cometics head gaskets because there isn't much cylinder wall left. If you are planning on supercharging, turbo charging or spraying the engine keep in mind that there is not enough room to o-ring the block at 454 cubic inches.
Old May 7, 2005 | 08:52 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Aren't there significant differences between LT series (i.e. eng mgt and cooling) and Gen 1 small block that make using non-LT pieces very difficult?
To Sbc454
