no cats with long tubes
Old May 7, 2005 | 04:26 PM
96dblblack's Avatar
96dblblack
Default no cats with long tubes
I am getting my EM longtubes in on Monday or Tuesday, so they say. I only ordered the headers and gaskets with the bolts. Assuming I am not running cats what is the best way to set this up. Pictures would be great. I would guess to hook up the headers and take to a shop for the rest. thanks in advance
Old May 7, 2005 | 04:29 PM
bogus's Avatar
bogus
and that shop would be so in deep **** if you have them bolt up the headers without cats. I would be surprised if they would do it.
Which leads to the second fact, the noise would be deafening.
Which, in turn, leads to the third fact, modern engines require a minor amount of back pressure to operate correctly...
Which, finally, leads to my preaching tirade about environmental responsibility and the low price a couple of bullet cats cost.
And don't say "it's only one car" cause if everyone did it, then we would have a massive air pollution problem.
Do the right thing - do the LEGAL thing and get some cats.
Old May 7, 2005 | 05:41 PM
vader86's Avatar
vader86
Put in a crossover, or X or H pipe, that will kill some resonance and put in just enough back pressure to help low-end torque.
Old May 7, 2005 | 06:16 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
How did I know I'd run into you here
I agree with a majority of what Bogus has to say. These motors don't gain all that much simply because the cats are removed. And bullet cats aren't all that expensive. It's just better to save the evironment in my opinion.
And finally... the deafening noise... well I'm still partial to the sound of open headers on a track... so I think the "noise" would be coool
Old May 7, 2005 | 07:16 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I won't get into laws and stuff...I will say I have long tubes running back to stock mufflers with nothing in between and the sound is all good....
Old May 7, 2005 | 08:27 PM
96dblblack's Avatar
96dblblack
Thanks for the answer without the lecture. There is no testing were I live, they did away with it about three years ago. I can say this about the testing, I know of two people who had gutted cats and still passed emisions testing with no problem. I would say that it was a one time thing but it was not. They passed year after year.
Old May 8, 2005 | 01:33 PM
aboatguy's Avatar
aboatguy
I know that you want to run without cats however, look at the LT with CATS picts in these threads and you might change your mind.
Mike
A4s with LTs and cats
Old May 8, 2005 | 06:20 PM
86PACER's Avatar
86PACER
I once fired up the car with just the headers on with no front y-pipe durring an install, just to see what is sounds like with open headers. It was so damn loud just idling outside my garage that the stuff on the walls where vibrating and buzzing, and I decided to not even take it arround the block. I wonder what it would sound like driving it on the street.
Old May 8, 2005 | 06:25 PM
99svrcpe's Avatar
99svrcpe
here ya go:
EM long tubes, EM header extensions, no cats, Corsa cat back
Old May 8, 2005 | 06:58 PM
93 ragtop's Avatar
93 ragtop
I have the long tubes with out cats and it sounds quite nice. There is no resonance and it is a little deeper then stock. This was through the stock mufflers and stock resonator. Next I removed the resonator and installed 2 bullet cats where they go. Sounds about the same as above.
As far as hooking up to the stock exhaust here is what I did. I got a 3 in connector and cut the left side about 2 in short of the header. I then used a small piece of the cut pipe (2&3/4 pipe) from the left side and slid it in the slip fit on the factory exhaust on the passanger side. I then purchased a 3 in pipe about 2 ft long from auto zone and slid it on the header and then slid the 2&3/4 pipe into the end of it. I then welded the 2&3/4 pipe to the 3 in pipe on both sides and I used 3 in band clamps on the headers. It does not look that great but you cant see it unless you are under the car. If you can get a exhaust shop to do it for you they could swell the pipe ends and make for a little better flow. In my area they wont touch it because of emissions.
Old May 8, 2005 | 07:56 PM
hippy's Avatar
hippy
I had a gutted cat and I hated it with headers and aftermarket mufflers.
Headers and a decent cat back sound good with a cat in place. For the 3-5hp you gain with no cat why wouldn't you have one?
BTW I ended up replacing my cat
Old May 8, 2005 | 10:04 PM
99svrcpe's Avatar
99svrcpe
I love the sound of mine.
What kind headers do you have? I'm not aware of any long tubes that are compatable with the stock cats or at least on LT1's
Old May 8, 2005 | 10:09 PM
FD2BLK's Avatar
FD2BLK
My stainless headers came with the pipes already bent, call EM and see if they offer somthing similar, and I welded them straight to the existing resinator.
Old May 9, 2005 | 05:43 AM
93 ragtop's Avatar
93 ragtop
EM does make a kit. I think I paid $195.00 for it. IMHO it does not work well on a automatic. The flanges hit the transmission. The turn on the passenger side hits the transmission as well.
Old May 9, 2005 | 07:27 AM
RichS's Avatar
RichS
Found the same problem putting them on my buddys 96 LT1. We had to have another pipe made to fit better.
Old May 9, 2005 | 07:47 AM
GS 163's Avatar
GS 163
I run EM longtubes, EM extensions, Dr. Gas x pipe, into Corsa mufflers. Sounds great and not deafening, but definitly loud.
Old May 9, 2005 | 09:31 AM
cv67's Avatar
cv67
St. Jude Donor '05
You would have to tell the shop the vehicle is for off road use only . Of course, if you have no testing in your area, it may still be legal for them to remove them. IMO removing cats makes the exhaust resonance "boom" a little too much .
To no cats with long tubes
Old May 9, 2005 | 09:59 AM
96dblblack's Avatar
96dblblack
Thanks for all the advice and the pictures guys. Bogus, you will happy to know that I have decided to go the cats route. I don't see eye to eye with you on your reasoning but I respect your o2. A lot of guys are afraid to put in writing things that can be seen as not popular. Good for you for having the courage to do so time after time when this question come up. I am going the cats route to avoid the noise issue and also to be prepared if testing ever does come back.
Old May 9, 2005 | 10:28 AM
jodyeastman's Avatar
jodyeastman
I Have EM longtubes and no cats. With the A4 I could not fit the cats. The longtubes were over lapping the Random tech cats on the corsa system. Anyway, it is louder at idle and under WOT but when crusing, it's no difference really.
Old May 9, 2005 | 10:51 AM
ratortor's Avatar
ratortor
Default no cats
I run an 87 with Hedman headers straight through to the end Borlas.
Sounds great but not offensive and runs even better.
If you want a muscle sound, this is the setup.
Good luck!
