new cam installed need help
Old May 8, 2005 | 10:41 AM
JAYK's Avatar
JAYK
Default new cam installed need help
Just finished with heads cam and intake install.LPE heads intake and 219 cam,shorty headers on my 94 LT1.I have not had the computer retuned yet,but car is idling badly around 600-625 and there is low vacuum and code 33 .Around 2000 rpm car starts to even out and run better and around 3000rpm is fine.Is this normal and just down to the computer needing a retune or have I missed something?help
Old May 8, 2005 | 11:58 AM
Bruce's Avatar
Bruce
Yup that was exactly the same happen on my car 93 with 219 cam and heads. I bump up the idle by adjusting the throttle body screw. It will run rich. After I got it tune, will be fine. But I was suggest to to leave it idle at 900rpm. Aftermarket should leave it idle at 625rpm it just simply to low.
Old May 8, 2005 | 12:06 PM
tjwong's Avatar
tjwong
Sounds like you need a PCM recalibration. I am surprised that you are getting a DTC33. That 219 cam is not very radical as far as cams goes. Many have installed a HOT cam without any reprogramming without any issues which is about the level of a cam as he 219. If you need help recalibrating your PCM you can PM me.
Old May 9, 2005 | 01:45 AM
JAYK's Avatar
JAYK
ttt
To new cam installed need help
