ABS Brakes
Old May 8, 2005 | 07:29 PM
89blakvette's Avatar
89blakvette
3rd Gear
Default ABS Brakes
The ABS motor check sound doesn't come after I first move the car at 4 mph. The anti-lock light also stays on. Any chance I can check and repair the problem myself.
Old May 8, 2005 | 08:06 PM
c4cruiser's Avatar
c4cruiser
You need to pull the codes to find out which portion of the ABS system is showing a problem. It could be the relay, any of the wheel speed sensors, or the pump itself.
Once you know the code, then you can figure out the repairs to be done.
In any event, check to insure all of the electrical connections (wheel speed sensors, ABS module connectors, and relay connection are tight. Also check the Brake fuse and the Gauges fuse.
Old May 8, 2005 | 09:39 PM
JAKE's Avatar
JAKE
Unless your 89 is different than my 86, you won't get a code. When my ABS failed a few months ago, no code, just a steady Anti-Lock dash light.
I dug into my library and came across a mag article on how to check the circuits and relays but even using that, I couldn't find the cause. It's in May 2001 Corvette Fever.
Someone then posted on how to jumper the ABS pump with 12v and it was supposed to turn on. When I did that, NOTHING, so I knew the pump was bad. I bought one from a Forum member and that cured the problem.
I later learned that jump starting the engine or crossing the battery charger connections or using the jump start setting on the charger can kill the pump.
If you don't have that mag, I can type it up in a doc file and send it to you. I suggest you check their website first, it may be posted there in the Tech Articles section. That'll save me a lot of typing.
Let me know.
Jake
Old May 8, 2005 | 10:37 PM
Jloshotz's Avatar
Jloshotz
i got lucky; replaced the relay near the ABS computer. Problem was solved.
Old May 8, 2005 | 10:46 PM
JAKE's Avatar
JAKE
Now you tell me; after I just finished typing up the procedure to check the ABS system. LOL
Yea, the relay is the most common cause of ABS failure.
Glad you have it repaired.
Jake
Old May 28, 2005 | 07:01 AM
tigmaned's Avatar
tigmaned
guys i know this is kind of old, but were are these relays you are talking about located? and the abs computer??
Old May 28, 2005 | 09:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You may find help from my 86 manual here........ http://members.shaw.ca/agent86/ABS.pdf
Old May 28, 2005 | 04:08 PM
JAKE's Avatar
JAKE
They're all inside the little compartment behind the driver's seat. I have a doc file showing the test procedure for them. Email me if you want me to send it. jakejr266@sbcglobal.net
Jake
To ABS Brakes
