From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Vats bypass module
Went to take the `87 to work this morning since it was such A nice day. Put the key in, turned it, everything lit up, heard the fuel pump, then NOTHING---Damned Vats . Waited ten mins. tried again---same result. Lucky it was in my driveway, since I had it out all day yesterday. This same thing happened a year ago right after I bought the car, & we had new keys made with new resistors. I do not want this to happen again, so I ordered one of those bypass modules from MAD for $24.99. My question is, does anyone use one & do they work. Oh yeah; after I got home from work, I went to start the car, & naturaly it fired right up. If the bypass works, I`m still going to hook it up when it comes, because getting stranded in some parking lot somewhere is total
Most likely the contacts in the ignition tumbler that make with the pellet are worn. You can prove this when it happens next time by removing the hush panel above the drivers feet and find the two white wires from the steering column that go to a connector. Unplug the connector and with the ign key inserted, measure the resistance across the wires from the steering column. It should be the same as the pellet. If over 13k ohms, you need a new ign tumbler which has new contacts. Also, you don't need to spend $24 to bypass your VATS. You can bypass VATS temporarily until you can schedule a repair by buying a 1/4 w 5% resistor from Radio Shack the same value as your pellet and clipping it across the connector that goes into the wiring harness (VATS module). Don't permanently bypass VATS because 99% of thefts are done by bashing the column and jumping the ignition. Also, you might have a defective clutch safety switch (gear selector sw if auto). You can bypass this switch next time it won't crank and try to crank again.
A fairly common (somewhat Bubba) Fix is to get a new ignition switch with a VATS key - and wire it in to the system - then they just leave that key in the switch - so it's reading the new ignition switch resistance. In the meantime - now you can use any cut key to start the car at the column - no resistor chip needed - and you can disable the car by turing off the second key under the dash.
I haven't done this - but after I bought my 86 - I discovered the second ignition switch and key under the dash- and eventually was able to figure out what was going on!
Carl Johansson
If one of your headlights burns out do you epoxy a flashlight onto your hood? When mine burn out I replace the headlight!
Do we measure the pellet resistance and then just order them or are there 'special places' that do it?
The best place (Price) I have found is a well stocked Locksmith shop. I got one for about 30% less than the Chevy dealer's parts department wanted, and the locksmith had a device that read the key value by just sticking the key into it. He also cut it in about 2 minutes.
Which one? the burned out one or the good one? Or are you replacing your flashlight with a headlight? How does that work? do you hardwire it to a car battery you carry around?
The VATs system is slightly more complex that a burned out headlight -
I/m betting that The module you are buying from MAM is going to be a simple resistor switch and some circuitry- about 2.38 at Radio Shack. But you would know better than me!
I already said I didn't do this - I'm just telling you what many have done. The fact is the VATS system causes lots of electrical gremlins - and lots of people have solved them in lots of ways.
Of course you are an Electrical Engineer so of course this bothers you. So if your tire goes flat - do you develop an electronic tire pressure sensor - linked to an autojackup system? Not me - I just change the tire - whatever works!
Reason: Add info
Sorry for jumping on your case since you didn't install the second ignition switch. About 10 years ago my 87 vette left me stranded at church and I figured out what was wrong and installed a fixed resistor so I could drive the car until I could schedule a replacement of the ignition tumbler. I have had no trouble since with the exception of the clutch safety switch failing which I jumped because it is impossible for me to replace it (too tight a space). What I am not able to understand is that forum members complain about their unreliable starting and even after they have determined it is the VATS and they never get it repaired and just continue to crab about getting stuck somewhere. Then other members start in with paying $24 for a bypass kit or putting toggle switches behind the dash and probably your cars previous owner recommending another outboard ignition switch. Get it repaired and get on with your life!!!!!!!!!!!!!!!!!!! sheeeeeesh
