??? hub bearing?? speed sensor??
May 11, 2005 | 04:03 PM
any help determining which hub bearing is required would be greatly appreciated!!
need a hub bearing for a 1996 ce
i have found different listings for just the hub bearing and then different listings for the hub bearing with speed sensor!!
also any reccomendations on whom to purchase thru would be greatly appreciated as well
cheers!!
May 11, 2005 | 05:45 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Go to
The last Detail and look up 84-96 REAR HUB BEARING, and 91-96 FRONT WHEEL BEARING HUB-(DELCO)
Unless you have a bad speed sensor, you don't need one. Just the hub is all you'll need.
May 12, 2005 | 10:39 AM
Thanks for the info. How do you know if you have a bad speed sensor?
May 12, 2005 | 05:03 PM
St. Jude Donor '06
I think you would have idiot lights on if the senser was bad ( ASR/ABS)
May 13, 2005 | 04:46 PM
May 13, 2005 | 06:39 PM
