good wires?
Old May 11, 2005 | 04:11 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Default good wires?
I'll make it brief:
For the same length of ignition wire, I get 5.8 Ohms of resistance in a Packard wire and 30 Ohms in an Accel using the leads of my Ohm meter connected at each end of the wire.
What gives?
I thought my new wires (Accel) were supposed to more conductive.
Anybody know what's going on?
Old May 11, 2005 | 06:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by Vett-eight-nine
I'll make it brief:
What gives?
No but I've just never been too impressed with lots of Accel's products. If you want low resistance, excellent resistance to header/ exhaust heat, etc., it is hard to beat MSDs.
Old May 11, 2005 | 06:43 PM
M.Clough's Avatar
M.Clough
Msd is the best for many reasons including the resistance of thier wires
Old May 11, 2005 | 07:07 PM
CFI-EFI's Avatar
CFI-EFI
Even 30 ohms isn't diddley. What kind of wire is that Packard? Solid metal conductor? The best wire for street use and lack of interference with on board electronics, is a spiral wound, low resistance, conductor. MSD is good, but over priced, in my opinion. Taylor, Moroso, and even the Summit house brand are very good wires.
RACE ON!!!
Old May 11, 2005 | 07:35 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm no wire expert, but I'm using Magnecor and have heard nothing but good about them and they've done just fine by me so far.
Old May 12, 2005 | 07:54 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
I have Taylor and have been happy.
Old May 12, 2005 | 08:41 AM
RWDsmoke's Avatar
RWDsmoke
The Taylor spiral cores make my radar detector go off at full throttle.
Old May 12, 2005 | 07:57 PM
Vett-eight-nine
I've heard good things about the wires you have all mentioned, but these Accels weren't supposed to be bad either...
I guess nobody's put an ohm meter to their wires, then?
I tested various lengths and they can't even hold the same resistance per foot! There's a huge difference even if one wire is only a few inches longer than another. I may have a bad set
To good wires?
