C4 hood clearance?
Old May 11, 2005 | 05:56 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default C4 hood clearance?
Can someone tell me how much hood clearance a C4 has under the hood? I guess the measurement would be from the bottom of the intake manifold to the hood. Thanks.
Old May 11, 2005 | 06:36 PM
Slalom4me's Avatar
Slalom4me
I do not have a direct answer to your question but
I can suggest a way for you to get a close
approximation for your specific vehicle.
Use a straight edge across the high point of interest
on your engine. Steady it in place with blocks of
wood stacked up on other parts of the underhood
area as necessary. Then measure down from the
bottom of the straight edge to the point of interest
on the block. If clearance does not not allow use
of a tape measure, use a piece of scrap strip or
wire that will fit, mark with a felt pen and then read
from this.
Then get plasticine, modeling clay or some similar
material. Shape into a cone, place this cone
pointy side up on top of the engine at the point of
interest, make sure you cleared away all tools and
supporting blocks then GENTLY lower the hood.
If every thing seems good down to the point where
you need to push to latch the hood, proceed to GENTLY
latch it. Otherwise, open the hood and trim down the
size of the cone.
Sum up the results of the two measurements and
you should have a fairly accurate idea of the
clearance.
Keep in mind that unless you are looking at
something REALLY novel, someone else has already
succeeded or failed at fitting it under the hood of
a C4. Wouldn't hurt to just ask whether what you
are considering has been done/will fit...
Old May 11, 2005 | 07:05 PM
jburnett's Avatar
jburnett
MOST C4's with OEM or OEM style engine mounts have 9.100" at the lowest point measuring from the front block rail (front manifold mating surface). If you're trying to figure out what manifold will fit I can tell you pretty closely...
-Jeb
Old May 11, 2005 | 07:27 PM
4bblC4's Avatar
4bblC4
I have an edelbrock air gap RPM w/ a 780 holley, pro flo air cleaner. Not much room, but it fits.
next mod: putting a 4" cowl on.
Old May 12, 2005 | 01:23 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you use clay, or a clay bar, just toss some wax paper on both sides, shut the hood, and yer done.
Old May 13, 2005 | 12:25 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Youve got an air gap? That is a pretty tall intake so i should be good. Thanks guys.
Old May 13, 2005 | 01:36 PM
vader86's Avatar
vader86
Throttle Body .9055"
Plenum where it begins immediately rearward of the TB: 1.07
Midway of the Plenum: 1.13
Very rear of Plenum but NOT onto the distributor cover: 1.15
Distributor cover: .7545
Old May 13, 2005 | 01:38 PM
CFI-EFI's Avatar
CFI-EFI
Are you leaving the Crossfire club?
RACE ON!!!
To C4 hood clearance?
