From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
How accurate are the DataMaster Calculators?
I've been recording and replaying datalogs using the Quarter Mile and Dyno calculators and have some relatively believable results. I know the dyno runs are relatively worthless...
But three recent 1/4 mile runs have very consistant numbers to compare.
The ECM outputs data that one easily can use for calculating the 1/4 mile and 0-60 mph. The calculation by Datamaster is accurate but the question is how accurate is the speed and distance outputed from the ECM.
You need to calibrate the vehicle speed and distance for your car, then you know how accurate your numbers from Datamaster are. If the speed and distance from the ECM (also shown in the dash) are accurate then (I beleive) the numbers are reliable.
Found some supporting data to backup these numbers. Turns out that a stock 86 coupe was rated at 14.4 for the quarter and 5.8 0-60. So this calculator is close to reality.....
Blower91 your right though, its best to calibrate the instrumentation rather than simply guess.
I've used it before by taking my personal car to the dyno I work at. then modifying the drag coeffecients to match the actual output in a second gear pull and presto, repeatable test bed without dragging my stuff on the dyno.
The time to distance in Datamaster is very close to my timeslip numbers.
Mine is very close too but I checked the accuracy of the data outputed by the ECM. I would not be surprised if someone out there will report poor accuracy though. 100% right does not happen often
