4L80E is in
Old May 12, 2005 | 05:34 AM
JoBy's Avatar
JoBy
Default 4L80E is in
Pictures here:
http://www.joby.se/corvette/mods/2004-12-26_4l80/
No cutting into the fiberglass needed. I only made a small hole for the TCI box cable.
Now I have to get a new driveshaft and build a new exhaust.
Old May 12, 2005 | 11:07 AM
MYCoupe's Avatar
MYCoupe
Very nice! This should hold up better than the 700R4 that's for sure. Let us know when you get it running again.
Old May 12, 2005 | 11:09 AM
CFI-EFI's Avatar
CFI-EFI
That looks nice Jonas. Great pictures. I like the way you boxed the end of the "C" beam to bolt to the back of the trans. One concern. It appears that all the "C" beam to trans bolts are in a single Vertical plane. Are there any bolts in the horizontal plane? I would be afraid that any forces that would be applied, would be more to the bolts than actually transfered to the trans. That's a nice clean installation. But coming from you, I'd expect no less.
RACE ON!!!
Old May 12, 2005 | 11:14 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Damn Dude Nice Work and Documentation
Old May 12, 2005 | 11:40 AM
mn_vette's Avatar
mn_vette
Dang! That looks great. I may have to try that next winter, depending on how mine holds up this summer.
How are you doing the electronics? What about the speedo plug for the ECM? Any major exhaust changes that you can see?
Old May 12, 2005 | 12:33 PM
comp's Avatar
comp
also how much heavier is it
Old May 12, 2005 | 12:40 PM
4bblC4's Avatar
4bblC4
mmmmm........ I'm gonna be puttin in a th400, wish I could afford that swap.
how much did you get it for, if you don't mind me asking. and did you do anything to it? (shift kit, input sprag, etc.)
Old May 12, 2005 | 12:50 PM
JoBy's Avatar
JoBy
I got the 4L80E and TCI controller for a total of about $1000.
I have done nothing to the tranny, and it is a low mileage from a chevy 3500 HD chassis cab. That is the reson for the odd tail housing. The bolt holes I used to mount the C-beam are originally for an extra parking brake.
The C-Beam is bolted to the tail housing using 6 bolts.
You can see it in these pictures:
( Click to enlarge )
Old May 12, 2005 | 12:59 PM
4bblC4's Avatar
4bblC4
wow, that's not a bad price at all....... maybe I CAN score one of those if I shop some more, then I'd have overdrive! yaay!
Great looking work by the way, not everybody can weld aluminum.
Old May 12, 2005 | 01:02 PM
JoBy's Avatar
JoBy
I get your point, but I dont think that it is a big issue. On the th700r4 the tail housing is bolted to the tranny using four smaller bolts, all in a single vertical plane. It is supported by the output shaft too, but still.
Old May 12, 2005 | 01:05 PM
JoBy's Avatar
JoBy
That was actually my first aluminum welding ... Even my first TIG welding.
Old May 12, 2005 | 01:58 PM
comp's Avatar
comp
nice
Old May 12, 2005 | 02:01 PM
CFI-EFI's Avatar
CFI-EFI
I'm at least glad that you understood what I was driving at. My concern is a little hard to verbalize.
The 4 bolts holding the tailshaft housing to the case on the 700R4, clamp the housing to the case, with a flat mating surface between the two and a pilot (I think). The forces on those bolts are in tension, parallel to their length. My concern was that the forces on your bolts are more of a rocking nature and with more leverage, with less of a surface area to prevent movement. You seem to realize what I'm talking about, so my mission is accomplished. It was not my intention to criticize, but merely point out what I saw. Regardless, I hope you find it trouble free.
RACE ON!!!
Old May 12, 2005 | 03:03 PM
JoBy's Avatar
JoBy
If you look closley on the tail housing there is a machined surface around the seal. I macined a hole in the 10mm aluminum with a lathe and it is a tight fit. There are no shearing forces on the bolts.
Old May 12, 2005 | 03:47 PM
mn_vette's Avatar
mn_vette
Where did you get the tranny and the controller for $1K? Did that include the TC and the flexplate as well? or were those seperate?
Old May 12, 2005 | 03:58 PM
bogus's Avatar
bogus
That is impressive. Very impressive.
I hope the c-beam is properly aligned, tho... if not, it can set off a vibration in the drivetrain.
Old May 12, 2005 | 04:39 PM
JoBy's Avatar
JoBy
I bought the tranny with TC for about $700.
The TCI contoller was also used and I bought that from someone else for about $300.
I bought the flexplate and yoke new from Summit Racing.
To 4L80E is in
Old May 12, 2005 | 04:48 PM
JoBy's Avatar
JoBy
The th700 is about 160 pounds. The 4L80E is about 250 pounds.
Old May 13, 2005 | 02:53 PM
4bblC4's Avatar
4bblC4
I am going to be fabricating my own c beam in the near future to mate up to my th400 w/ a 9" tailshaft.
Is there anything I should be watching out for as far as alignment of the c beam? Is there a pinion angle I should have or anything?
thanks!
Old May 13, 2005 | 05:27 PM
comp's Avatar
comp
wow,,, more than i guessed
