I have the clutch apart and noticed. On the flywheel, you have the front plate where the ring of gears are and then the back plate or clutch surface area. This is one big unit. I can move the back face or clutch plate that the pressure plate bolts up to. Side to side about 1 inch. The flywheel or front plate does not move at all when I do this. Is this normal. Thanks Mike
If it's by hand, the dual mass flywheel is junk. Sorry. Contact Tom at Carolina Clutch, he can get you one, or, Chris at Superior Chevy, 1.800.728.8267.
I have heard good and bad on these. Do they really make as much noise as some say? How do they compare to the duel mass? Any good locations on the west coast to buy a fly wheel.
