Superram Question
Old May 17, 2005 | 06:24 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Superram Question
I was test fitting my sensors on my motor.
I've noticed that the oil pressure switch is tall. The lower manifold get in the way.
What did you guys do? Or am I put the oil pressure switch in the wrong place....
Old May 17, 2005 | 07:09 PM
scorp508's Avatar
scorp508
Can you take a picture? There should be no issues with the sensors.
Old May 17, 2005 | 07:30 PM
cplonner's Avatar
cplonner
i had a that same problem with the scogginsdickey/edelbrock big mouth manifold, i had to rig fittings so it would fit properly a little bit of a pain but it worked, let my know if you find a different solution. i called edelbrock and asked if they had a fitting kit that fit that and they said no.
what is your made by? accel? lingenfilter?
Old May 17, 2005 | 08:33 PM
Coupe89's Avatar
Coupe89
I'll take a picture tonight. Its made by Accel
Old May 17, 2005 | 09:07 PM
dock351's Avatar
dock351
St. Jude Donor '06
If you are referring to what I think you are, on my '90 L98, the oil sensor and switch are located on what i will call a 'stalk' at the upper/center/back of the engine. It doesn't interefere with the Accel intake manifold base at all. But I will wait for your pics
Old May 17, 2005 | 09:15 PM
LD85's Avatar
LD85
It will clear, grind some off of the hex on the pressure fitting if you have too.
My TPIS Big Mouth was close but fit with no grinding.
Old May 17, 2005 | 09:35 PM
Coupe89's Avatar
Coupe89
I forgot to add this tid bit of info its on a SBC 400
Old May 18, 2005 | 02:32 PM
Coupe89's Avatar
Coupe89
Anyone ???
Old May 18, 2005 | 02:40 PM
Caboboy's Avatar
Caboboy
You use a brass pipe nipple there Todd......I'll shoot you a call
Old May 18, 2005 | 05:22 PM
pablocruise's Avatar
pablocruise
This is how my 89 came:
I believe I might have even clearanced the superram base slightly to allow this elbow's flanges to turn(???)
I sold it to Tim, maybe he can see.
Old May 18, 2005 | 06:34 PM
Caboboy's Avatar
Caboboy
Hi Paul, hope all's well for you & yours
I'm hooking up with Coupe89 on a run this Saturday. I'll give him a look under the hood & we'll get it ironed out. Now that you mention it, I don't remember if that SR you sold me was clearanced.............I'll have to look when I get home from work tonite.
Old May 18, 2005 | 07:06 PM
Coupe89's Avatar
Coupe89
Paul: Thats a short sending unit. Where is that from ?
Old May 18, 2005 | 07:45 PM
pablocruise
It's actually the same kind you show in your pics, only that I broke off the one in my pic.
Old May 19, 2005 | 02:52 AM
rodj's Avatar
rodj
My '89 engine has the same large sensor but had the other adapters fitted (stock) to move it clear of the manifold.
Old May 19, 2005 | 04:20 AM
steve1ph2's Avatar
steve1ph2
yea. you dont have the l shaped nipple. standard. by the way have you fitted the valve covers with the runners in place? need to answer the last question.
To Superram Question
