Engine stumbles and dosent stay running...help
Old May 18, 2005 | 12:09 AM
vetteguy216's Avatar
vetteguy216
Default Engine stumbles and dosent stay running...help
earlier last year I attempted to install my superram but failed to do so becuase of some threads that were striped so I put my TPI back on using the old gaskets which I knew were shot but did it anyways there was a small vacume leak but the car generally ran fine. this week I got back from school so I took the car for a dirve it was ok...but then it started to stumble under light acceleration but ok under hard and when in neutral it was fine. I decided to install some new gaskets and now the car has a slight stumple and in neutral but stumble constantly in drive it will also stall when idleing. I did notice that at idle it produced 13.7 volts and through the whole rpm band it stayed at 13.7-13.8 is the alternator bad/could it be causing this. Its an 87
Also last year I was having similar problems with my 1994 f-150 but it was a lot worse. and then it was the alt. when replaced it ran fine.
Old May 18, 2005 | 01:37 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The first thing I would do is ,check for codes.
Remove the pos wire on the batterie and clear codes and see what happends after about a 5 mile drive.
Old May 18, 2005 | 03:37 PM
vetteguy216
I dont know if it would last 5 miles and the check engine light is not on
so can there still be codes if the light is not on?
Old May 18, 2005 | 06:10 PM
vetteguy216
wow after posting the last post I went out to work on the car and it ran fine like nothing was ever wrong. Man im glad my car likes to fix itself
Old May 18, 2005 | 11:01 PM
JAKE's Avatar
JAKE
[SNIP=vetteguy216]Man im glad my car likes to fix itself[/SNIP]
Don't worry, it didn't.
Jake
Old May 19, 2005 | 07:59 AM
runner140*'s Avatar
runner140*
Jake
You're right.
To Engine stumbles and dosent stay running...help
