Injector question
Old May 18, 2005 | 06:41 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Injector question
When I replace my injectors, what gaskets ect. if any do I need?
Old May 18, 2005 | 07:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
To replace the injectors on an L98 you need to remove the TB, planum, runners and fuel rail.
If it's the first time in there I would just get a FelPro intake gasket set from AutoZone for around $35, which would contain all the gaskets needed plus the two for the intake base.
I've been into my intake system so frequently in the past four years that I just reused all my old gaskets when I installed injectors a copla weeks ago, with no vacuum leaks.
