ok,havent seen a thread like this in a while,here's the scenario,96 LT4vs.95 ZR1,little bro,vs.big bro,at the dragstrip,and the dyno.both cars bone stock.although I never saw head to head,same day,etc.did some research,heres what I found,its all hypothetical and for fun for those who've always wanted to know,which was quicker
LT4 pulls out better,but ZR1 catches it by 50 mph(0-60 for LT4 is 4.7,ZR1 is 4.5)then 32 valves kick in,and by the 1/8 its ahead,and nips it by the 1/4.who has some realworld experience between the 2?
Screw the ET... Look at the mph; that's more power out of the LT5, plain and simple. The disparity between the two is all in the short time; 1.93 vs. 2.08. For every tenth in 60' it's worth two tenths in the 1/4. Less torque, different driver, who knows what other variables between the two vehicles. Additionally a simple degreeing of the stock cams on an LT5 is often worth 40-60 hp...
I have been tuning one memebers ZR1 on my dyne, and as Jeb said with degreed stock cams, this 368 LPE car with ported runners and plenum laid down over 450Hp on my Mustang dyne at 7000 RPM
The LT4 is newer and is therefore better. Simple as that (well, that and the LT4 comes in a vert). Who cares that the ZR-1 is an exotic, has more hp, tq, 32 valves, DOHC, holds world records and shows most cars its tail lights after 100 mph.
On the drag strip they are close, on the street there is clear winner.
They are both very nice Corvettes, so you really can't go wrong with either.
The LT4 is better because it is newer????? I dont think so...the LT4 came out in 96 nad the ZR1 ended in95...........one year.
Trust me, the LT5 makes 75 more rated hp than the lt4 (405 vs 330)....trap speeds dont lie.
the LT5's were built back in the late 80's, early 90's and stored. They are quite a bit older than a LT4. I do however disagree with newer=better. Perhaps in some cases, but I'd opt for the ZR1 over an LT4 any day.
Were did you get the rwhp numbers from? I just read a post in the ZR1 forum not long ago that in 95, the heads were manufactureed by a different supplier and a stock motored 95 put down 365 at the wheels.
You wouldn't believe the power variances between different Zed's of the same year... Again, a simple degreeing of the stock cams can often pick up hella-numbers. For such an expensive, hand-built engine by a small supplier (if you can call Mercury Marine "small") I'm amazed at the descrepencies between them.
-Jeb
I personally witnessed a 90 put down around 360 in basically stock trim, only K&N and an inexpensive-type catback.
The convertible thing did it for me. I like to feel the wind in what's left of my hair. I don't think that newer is therefore better holds true.
I've raced against and test drove both many, many times over the years. Those LT-4's do really well at the track with a good driver.... most go mid 13's, but I've seen some experienced racers take them into the high 12's bone stock.... thats pretty impressive.
ZR-1's seem to have a big variety.... I've seen them go as slow as high 13's and low 14's, although obviously the driver needed a lot of work. One guy at Carlsbad several years ago had 4.11 gears, exhaust and I think an aftermarket air cleaner of some sort and after some practice ran a 12.5 @ 114 mph...... thats pretty darn good too !!
I'd take either one myself.....but if I had to pick one.... you gotta like a maintenance free motor that you can take up to 7500 rpm !!
cheers,
Beach Bum
Beach... I hate to be a fly in the ointment.. but my stock motored LT1 has run 12.28 @ 110 & its an automatic, which we all know runs less MPH than a stick.
I'd love to have either of the other two LT4 or ZR1 but not to bracket race with... My LT1 does very well vs the "Big Boys" at E Town
