Knock Module
Old May 21, 2005 | 03:51 PM
96dblblack's Avatar
96dblblack
Default Knock Module
I just replaced my cam with a high performance one along with new valve springs. I am wondering if I need to look into a LT4 knock module instead of the LT1 that I have now. I heard that the LT4 one is more forgiving the the Lt1. Any thoughts, or have some of you done this before. BTW 96 LT1.
Old May 21, 2005 | 05:44 PM
STL94LT1's Avatar
STL94LT1
If you have the software, run a datalog and see if you are getting spark retard. If no spark retard is occuring, the LT4 K/M will work no better than your stock LT1 K/M.
Sometimes with a camshaft/rocker upgrade the engine's harmonics will increase. The LT4 K/M will help the knock sensors from retarding spark, from this extra noise.
Old May 21, 2005 | 06:02 PM
FD2BLK's Avatar
FD2BLK
What he said
To Knock Module
