Quick question: Which distributor wrench?
Old May 23, 2005 | 05:44 AM
86PACER's Avatar
86PACER
Originally Posted by CentralCoaster
Then some fat mexican chick in the back seat of a little ****box import says, "I like your truck, why are you driving around in mexicanized truck?"
It's a 100% stock F150. Dumb ho.
Dumb people out there
Old May 23, 2005 | 07:13 AM
LD85's Avatar
LD85
I got mine at Autozone, it came with two boxed in 12-point wrench head that can connect to a 3/8" socket wrench
Old May 23, 2005 | 08:10 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Originally Posted by bogus
Sears has the exact tool you want. It's like 9.95.
Thats the one i have. Worx Great
http://www.sears.com/sr/javasr/produ...id=00947683000
Old May 23, 2005 | 01:23 PM
JAKE's Avatar
JAKE
Most auto parts stores carry them, usually hanging on the rack in the HELP! section. I've seen them two in a package for less than $10.
One of them is 1/2" and the other 9/16", both are 12 point, box end.
Your engine takes the 9/16" one.
Jake
Old May 23, 2005 | 04:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Jake
You just qualified to head the parts department at the San Diego Napa regional distribution center. You obviously know more than he does.
Old May 23, 2005 | 05:25 PM
JAKE's Avatar
JAKE
LOL, Naw, I just play with my distributor so often that it's easy to remember.
Metrics will fit too, I believe a 14mm is pretty close; may be a little on the tight side. I'm pretty sure a 15mm is too big though.
The distributor wrench itself is bent into an "L" shape so it fits nicely under the distributor housing. As I said, the kit comes with two wrenches and one little adapter. The adapter fits both wrenches and looks like a socket, has sort of a cross-hatch pattern on it but, unlike a socket, it has 3/8" square openings on both ends.
One square opening snaps onto the distributor wrench. I then install a 12" long 3/8" extension into the other square opening. I just attach my 3/8" ratchet to the extension and use the ratchet to loosen or tighen the bolt.
The use of the extension keeps my hands high up, well away from anything that's hot and from any obstacles like hoses and wires, etc.
Jake
Old May 23, 2005 | 07:01 PM
Caboboy's Avatar
Caboboy
Let's say I did that then took it back to sears to get a new one. Think they'd go for it?
That's an old throwdown from my teenage years......I think it may be 40 years old now
