Found my charging problem!
Old May 22, 2005 | 06:18 PM
TIMSPEED's Avatar
TIMSPEED
Default Found my charging problem!
Damn negative battery bolt was loose! Remember, check those bolts ladies and gentlemen! LUCKILY, before running around in circles, testing circuits for continuity, I checked the bolt FIRST, and it happened to be DAMN loose.
Maybe now I'll run those 13.0's (hey, couldn't hurt to dream, haha)
Old May 22, 2005 | 08:33 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Had all kinds of head scratching on my LTD... turned out to be a rusted out ground cable.
That fixed 142 of my 695 electrical problems.
Old May 23, 2005 | 01:39 AM
ClarenceT's Avatar
ClarenceT
I had to rewire the whole charging system... Everything was eroded, insulation shrunken, wires exposed, blocks crumbling appart... The dist block behind the battery was a total loss, I guess a bunch of acid got on it at some point in time.
To Found my charging problem!
