Steering column play?
Old May 22, 2005 | 07:21 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Steering column play?
Need some help....
Have a 93 Coupe......Tilt Column has some play in it. Typical when used as a LEVERAGE DEVICE for personal extraction from vehicle.
How can I repair this?
Old May 23, 2005 | 09:36 AM
dchildress's Avatar
dchildress
I have the same problem (I think)...when in driving position, if I push the left bottom corner (say the 7 o'clock position) my steering wheel moves about 1/2". I have been told, pull the steering wheel and some of the guts inside the column and tighten some bolts down inside. The guy who told me this did the body work on my 1970 Monte I am restoring. He said it is about 3 to 4 hours. If you find this advice to be true, please let me know.
Old May 23, 2005 | 10:35 AM
cv67's Avatar
cv67
St. Jude Donor '05
Anyone have step by step instructions? I've had one tilt column apart before and wound up with spare parts Mine's a little loose also..
Old May 23, 2005 | 10:44 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I received the same response for the shop that did work on my car. When asked, they replied that is was not a safty issue.
Old May 23, 2005 | 10:48 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Yeah mine does it too.
I never want to fool with it due to the airbag.
Old May 23, 2005 | 11:02 AM
jsaunde2's Avatar
jsaunde2
Do some searching, there's threads all over about this and also a tech tip.
There is a spring service kit that includes 5 or 6 little parts for the steering columns also. It's about $20.
I'm going to be doing this on mine soon, I'll try and take pictures and get a step-by-step together.
Jason
Old May 23, 2005 | 04:34 PM
KNCRSR5R's Avatar
KNCRSR5R
I had searched a little...but with no luck. Will try again. I will also take pics when I did into mine. THIS HAS GOT TO BE FIXED before any track time. MAN......just pulling into a sweeping left hand curve near the house was VERY Scary!
I'll keep posting with progress!
Old May 23, 2005 | 04:38 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
bogus wrote a nice tech tip (HERE) that covers the basics pretty well. If you do not have a factory service manual (Helm not Haynes) then you better get one because there are a lot of little parts that all have to back in a certain order or things won't work right - plus the pictures and diagrams help visualize what is going on.
That said, I just did mine about two weeks ago and it was relatively simple. Getting the column out of the car was the worst part - lots of wires down there. Pulling the airbag is no big deal - 2 screws and one wire - just don't go probing around with a powered test light or multimeter all is well. I got the tilt column rebuild kit from Superior Chev (CF discount rocks) for $20. The two little pivot pin replacements did the trick - column is nice and firm now. My horns also work better after I put everything together.
If you have problems, ask the forum. Many have done this and can offer help if needed.
Old May 23, 2005 | 05:03 PM
KNCRSR5R's Avatar
KNCRSR5R
Thanks DALE
Thanks for the info!
Old May 23, 2005 | 05:27 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
99% of the time it's the base bolts in the column that are loose...It's quite a PITA if you've never done one and requires a pivot pin puller and the correct size torx socket in addition to a lockplate tool...It DOES become a safety issue if it gets worse..
Old May 24, 2005 | 08:53 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
You may or may not need a pivot pin puller. On my column, the pins were so worn that they practically fell out. I bought a puller but only used the threaded part to yank them out. The new ones went in real tight like they should.
The rest of the special tools (wheel puller and lock plate compressor) are available for rent at Autozone and Oreilly's. They are also pretty cheap if you cannot find a rental.
Old May 24, 2005 | 10:40 AM
92Rawket's Avatar
92Rawket
8th Gear
Hey Dale, I am new at this but does Superior Chev give a discount to CF members? I would like to buy that steering column service kit. Do I need to call them and tell them I am a member?
Old May 24, 2005 | 10:51 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
www.superchevyperformance.com
Call em and ask for Chris May
Old May 29, 2005 | 01:09 PM
sick-punk's Avatar
sick-punk
ok, i just got my vette and there is a ton of play in my steering colum "safe i think not" if i took this to a shop how much you think this would run me...
Old Jul 7, 2005 | 04:35 PM
cwdancer's Avatar
cwdancer
4th Gear
Took my '87 in to a Chevy dealer for "loose bolts". Estimated $275 to $375. Bad luck.... cracked aluminum part. Part no longer made so we found a salvaged steering column and completed job for $1000.
To Steering column play?
