Ngk Tr55
Old May 23, 2005 | 08:58 AM
STL94LT1's Avatar
STL94LT1
Default Ngk Tr55
What is the optimal gap to run on a heads/cam LT1 with NGK TR55 plugs?
Old May 23, 2005 | 09:14 AM
Strick's Avatar
Strick
I stayed with what the General said to use. (.050")
Old May 23, 2005 | 12:48 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Old May 23, 2005 | 01:21 PM
R23HTC's Avatar
R23HTC
Originally Posted by onedef92
I'd stick to .050 as well, unless your spraying or you raised your compression a bunch. Then you might consider something a little smaller to keeping it from flaming out.
Old May 23, 2005 | 02:15 PM
pwrful c4's Avatar
pwrful c4
If your running a little hotter spark you can widen the gap.
Old May 23, 2005 | 04:01 PM
onedef92's Avatar
onedef92
I just want to add I'm very happy with the TR55's. I wanted to go with the NGK Iridium's but at $8.49 a pop, they're a little too rich for my blood for a set of 8.
Heck, my entire tune-up (minus the Mobil 1 oil and filter) was $54.85 since I purchased the parts from NAPA.
Old May 24, 2005 | 07:15 AM
STL94LT1's Avatar
STL94LT1
Thanks guys.
To Ngk Tr55
