New IC is done!
Old May 23, 2005 | 09:56 PM
AKS Racing's Avatar
AKS Racing
Default New IC is done!
If I could get someone to host, I would like to get these pics up on the forum. Or maybe someone could explain how I could post them?
All internal welds smoothed. PSI tested to 50 psi, no leaks. IC core measures 22"W x 5.5"D x 15"H. Unit feeds from bottom to top. Mounts off each side to mount on the frame rails, just aft of the hood hinges. Much simplified piping. 3" oval feed into IC offset to passenger side, 3.5" oval dischrge directly into TB area (requires bell to go from 3.5" discharge to 4.5" TB feed).
I have sent a bunch of pics to Bruce, but no luck to date.
Anyone want to host?
Thanks,
Aaron
Old May 24, 2005 | 12:29 AM
lcvette's Avatar
lcvette
send them my way man.. i can host them up for ya!
Chris
Lcvette1@aol.com
Old May 24, 2005 | 07:53 AM
Bruce's Avatar
Bruce
Sorry Aaron
I got 4 pics from you Friday, for some reasons I would not able to see them. I emailed you and ask you to try to send it again. I have not see any other emails from you. Onr thing I know about my Road Runner cable internet. Some time people emailed me and it did not showing up in my mail box until few days later. Don't know why.
Bruce
Old May 24, 2005 | 08:15 AM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Thanks,
Aaron
If you still need a host, email me
Scott_Rivkin@rsausa.com
Old May 24, 2005 | 05:41 PM
lcvette's Avatar
lcvette
just got home from work.. here ya go though !
looks nice man!
Chris
Old May 24, 2005 | 06:46 PM
LPDesRoche's Avatar
LPDesRoche
Aaron, that looks sweet man!....I need one like that for the 94. Where did you get the IC core material from? I see you have another big chuck sitting on the table so I assume you bought it in bulk from somewhere?
Old May 24, 2005 | 08:09 PM
AKS Racing's Avatar
AKS Racing
When I purchased the single core (5.5"D x 22"W x 15"H), you only got a break on the price by purchasing three raw cores. So Three were purchased. The real time was in the design. It is fully documented on ACAD. I had the majors quote the IC, and one came in at $1975 w/out the side brackets, the oval tubes and the IAC mount. The other quoted as designed and it came in at $2185. These prices were too high, so I decided my design would have to work.
Needless to say, here it is.
Chris,
Thanks for hosting.
Aaron
compulsivehp's Avatar
compulsivehp
What you doing with an MKIII Supra in the back ground? I used to own several of those adn have rebuilt 4 of them. Im about to help a buddy rebuild a 400rwp with ans SP67
Old May 24, 2005 | 08:21 PM
ztrips's Avatar
ztrips
Crap that's thick... Can't wait to see pics of it installed....
Old May 28, 2005 | 11:15 PM
Hippiehead025's Avatar
Hippiehead025
what kinda HP numbers can it support?
Old May 30, 2005 | 02:00 PM
AKS Racing's Avatar
AKS Racing
According to the calculations, this unit should support 2800 cfm flow at >0.5 psi drop. That should put it capable of supporting way past 1000 RWHP, which would easily handle my combo.
The single largest limiting factor in my design on both flow and strength was the offset 90° turn 3.5" oval feed inlet at the bottom. This proved do be tough, but with a little creativity, I expanded the chamber and added a divider plate. There was no expansion at 50 psi, so all is well.
Aaron
Old May 30, 2005 | 07:12 PM
TONYDEE64's Avatar
TONYDEE64
That looks real nice... great Tig welds... I would only worry about getting enmough flow to the radiator. Mine looks a bit like yours (except mine is only 3.5" thick) and air flow is a problem. I made a ram air box that fits to the front of the IC to direct air through it.. seems to help...
To New IC is done!
