[PICs] EM headers / 3inch exhaust back
Old May 23, 2005 | 10:19 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default [PICs] EM headers / 3inch exhaust back
Below you will find a few pictures of my new exhaust. The installer cut off the end of the seatbelt mounting bolt, not happy about that. I wish he had used a narrower x-pipe or bent the pipes a little. otherwise, VERY NICE work.. happy with it...
Old May 23, 2005 | 11:07 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Looks a little restrictive still - were they out of 4" pipes
Old May 23, 2005 | 11:08 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Old May 23, 2005 | 11:13 PM
vettefun's Avatar
vettefun
All that sweet exhaust and he's worried about that milimeter shaving off his seat bolt!!! I wish I had such problems.
LOOKS AWESOME. Love the X pipe. Let us know how it sounds and performs. I'm looking to do similar exhaust myself.
Old May 23, 2005 | 11:27 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Thanks... don't get me wrong... The exhaust work is very nice but I wish he had bent the pipes a little instead of cutting off the end of the bolt. Not a big deal. Just the thought of cutting something off on my car doesn’t sit well.
The car is LOUD!!! I drove home with the power effects open and it's loud. Still has that "race car" (not my description) sound but the tone is higher and of course louder with the x-pipe. I think I lost a little low end torque but the car is more responsive, more alive in a way..
Old May 24, 2005 | 01:46 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
He did no harm cutting the bolt off. If you ever remove it, it will make it a little harder to start threads, but it will not affect the strength of the bolt.
In fact, you're probably better off as now it will conduct less heat throught it to warp plastic and rust the bolt.
Nice install.!
Old May 24, 2005 | 05:39 AM
93 ragtop's Avatar
93 ragtop
Really nice job. Did you have the 3 bolt flanges welded on your headers or has EM redesigned them?
Old May 24, 2005 | 06:31 AM
ruffneckxx's Avatar
ruffneckxx
Cruise-In VI Veteran
St. Jude's Donor '06
Diesel exhaust size
Old May 24, 2005 | 07:30 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Nice install.!
ok... I need to spray some paint over the area he cut because it's exposed metal now, but not a big deal.
Old May 24, 2005 | 07:31 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
thanks... I asked him to flange the EM headers. The tuner installed the Wide band O2 bung.
Robert
Old May 24, 2005 | 07:32 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Originally Posted by ruffneckxx
Diesel exhaust size
I think I should have waited for the 4inch pipe to come in, on back order.
Old May 24, 2005 | 08:13 AM
93 ragtop's Avatar
93 ragtop
Robert
I had thought about doing the same to mine. I have not had much luck getting the slip fitting and band clamp to seal. Could be I am doing something wrong though.
Old May 24, 2005 | 08:15 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Mine leaked too... one reason why I asked him to install the flange.
Old May 24, 2005 | 08:20 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Narly
Old May 24, 2005 | 09:01 AM
STL94LT1's Avatar
STL94LT1
Cut slits in your slip fit pipe/cat, and the band clamps should work fine.
Old May 24, 2005 | 09:02 AM
JoBy's Avatar
JoBy
I have never been able to get a good seal with that 3-bolt flange. I am converting my Hooker 2151 to V-band clamp instead.
Old May 24, 2005 | 09:18 AM
Strick's Avatar
Strick
Can you drop the entire exhaust now? If so, do it and paint the entire exhaust with a very high temp ceramic paint. It will last a lot longer and even look better. Just an idea.
To [PICs] EM headers / 3inch exhaust back
Old May 24, 2005 | 09:28 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Nice exhaust. Should flow well!
Whats with the large plugs in the headers?
Also get ready for a warm cabin. With the pipes as close as they are to the body you are probably going to need some heat shielding. I am running into this problem right now.
Old May 24, 2005 | 09:45 AM
FELNGR8's Avatar
FELNGR8
Nice installation. Robert does a fine job on fitting them into the space available.
Those 3 bolt flanges are very handy when it comes time to do other things like replace the clutch you'll blow up, or a Hurst shifter.
What brand of cat are those? My random techs don't have the full heat shield, only on the top.
Old May 24, 2005 | 11:18 AM
96dblblack's Avatar
96dblblack
Man that looks really nice. I can't wait to install mine.
