Front Suspension
Old May 25, 2005 | 01:43 PM
1986coupe's Avatar
1986coupe
Default Front Suspension
My Corvette was lowered by a previous owner. I am having it raised back to its original height. I understand that to lower it the rubber bushing are removed from the spring. Does anyone know the thickness of these so that I can have something fabricated?
Any other suggestions would be greatly appreciated.
Old May 26, 2005 | 08:22 PM
tigmaned's Avatar
tigmaned
i would think you could just get the stock cushsions or what ever was taken out no?what don't you like about the lowering? the ride or hitting things?
Old May 27, 2005 | 01:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
When lowering, those pieces are literally cut and dremeled and shaved and ground off of the spring. You couldn't really glue em back on.
Best bet is to put the aluminum spacers back in, or make ones that are an inch thick or so. These go against the frame above the spring pivots.
Are you sure your front spring isn't just delaminating? Pretty common.
To Front Suspension
