Bad Teeth on Starter
Old May 25, 2005 | 09:43 PM
SDS Photography's Avatar
SDS Photography
Default Bad Teeth on Starter
My grinding problem at startup has been linked to some bad teeth on my starter. While I am having my intake swapped (blown gasket ) I was wondering if I should swap this out. I am not sure but I would guess that it will just get worse and worse till it will not start but I am not sure how quickly this will happen.
thanks guys
Crazy
Old May 25, 2005 | 10:21 PM
JackDidley's Avatar
JackDidley
Replace the starter. If you dont it will eat the teeth on the flywheel. If it hasn't already.
Old May 25, 2005 | 10:49 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Definitely examine the flywheel closely, all of the way around. If it looks good, you got lucky. If the starter is otherwise good, you could just replace the starter drive, what many call the Bendix. This involves some disassembly of the starter.
Old May 25, 2005 | 11:03 PM
SDS Photography
where can i find a Bendix?
Old May 25, 2005 | 11:30 PM
aboatguy's Avatar
aboatguy
Just about any autoparts store!
To Bad Teeth on Starter
